Last Updated: September 17, 2026Travel Tips
When should you call roadside assistance vs. handle it yourself?
Pickup truck cruising a scenic two-lane road lined with evergreens in the mountains.
GS
Good Sam
“Sometimes it's not the problem that's dangerous, it's where you're stuck. Learn when to handle a roadside issue yourself, when to call for help, and how to stay safe doing both.”
You should call roadside assistance when your vehicle is stopped in traffic, on a highway shoulder, in severe weather, at night, or when it cannot move safely. Even minor mechanical problems become dangerous when visibility, traffic speed, or vehicle size increases risk.
Some roadside issues, such as adding washer fluid or tightening a loose battery terminal in a driveway, can be handled safely. But when exposure to traffic or environmental conditions increases, requesting professional help is usually the safer and more practical choice.
This guide will help you confidently decide what you can handle yourself and when it’s time to request help.
Quick Decision Guide: Should You Call for Help?
If you’re wondering, “Should I call roadside assistance?” use this simple comparison.
Usually Safe in a Secure Location
  • Adding windshield washer fluid or coolant.
  • Adjusting tire pressure in a parking lot.
  • Replacing a key fob battery.
  • Tightening a visibly loose battery terminal.
  • Addressing a minor issue noticed before driving.
These are generally low-risk tasks, but location matters. A simple repair in a driveway is very different from the same repair on a highway shoulder.
Better To Request Roadside Assistance
  • Flat tire on a highway or narrow shoulder.
  • The vehicle won’t start away from home.
  • Steering or braking problems.
  • Engine overheating while driving.
  • Locked keys inside the vehicle.
  • Dead battery at night.
  • Severe weather conditions.
  • Any RV or trailer breakdown.
In these situations, the real risk isn’t just the mechanical issue. It’s traffic exposure, reduced visibility, or vehicle weight and stability.
Ultimately, the where is often more important than the what. A flat tire is a simple mechanical task, but performing it a few feet from traffic moving at highway speed introduces a level of risk that far outweighs the benefit of fixing it yourself.
What Problems Can Drivers Usually Handle Safely?
Not every vehicle issue requires professional help. Some problems can be handled safely if your vehicle is parked in a secure, low-traffic location.
Low-Risk Situations
There are times when handling a vehicle issue yourself is reasonable. These are typically low-risk situations where the vehicle is parked in a controlled environment, such as your driveway, a spacious parking lot, or a well-lit rest area.
  • Dashboard Alerts Before Driving: If a warning light appears before you leave home, you have the advantage of time. You can check fluid levels, inspect obvious concerns, or schedule service without roadside exposure.
  • Minor Battery Connection Issue: If your car won’t start in your driveway and you notice a loose battery terminal, tightening it may resolve the problem. If the car still won’t start, it’s safer to request a jump start rather than repeatedly trying to start it.
  • Low Tire Pressure in a Parking Area: If your TPMS light comes on near a gas station, adjusting the pressure to the levels listed on your door jamb is a routine and safe task.
  • Non-Urgent Maintenance Reminders: Oil life indicators or routine service alerts do not require roadside repair. Schedule service at a convenient time.
But if you feel unsafe at any point, even after starting the task, stop and call for help.
When You Should Always Call Roadside Assistance (High-Risk Situations)
Safety experts agree that certain conditions make roadside repairs too dangerous to attempt. In these high-risk scenarios, professional equipment, visibility, and traffic awareness are essential.
On Highways or Narrow Shoulders
Highways are designed for speed, not repairs. If you are on a freeway, interstate, or even a busy rural road with a narrow shoulder, stay in your vehicle (if safely out of traffic) and call for help. Passing vehicles may be only a few feet away, and distracted drivers pose a serious threat to anyone standing outside a stationary car.
At Night or Low Visibility
Even with hazards on and flares placed, other drivers have much less time to react at night. Professional roadside technicians use high-intensity LED light bars and reflective gear that make the scene far more visible and much safer. If you break down or have a flat tire in a low-visibility area, it’s safe to stay inside your locked vehicle and wait for help.
Severe Weather
Rain, snow, ice, or extreme heat complicates any repair. Wet roads increase stopping distance for approaching cars, cold weather reduces dexterity, and extreme heat can quickly lead to dehydration or heat exhaustion. Trained technicians have the gear, protective equipment, and training to work safely in these conditions.
Vehicle Won’t Move or Steer Properly
If your vehicle feels unstable, won’t shift into gear, or the steering wheel feels loose or unusually heavy, do not attempt to drive it. Trying to move with a damaged axle, transmission failure, or steering problem can cause complete loss of control or worsen the damage. In these cases, a tow is the safest option.
RV, Trailer, or Heavy Vehicle Breakdowns
Larger vehicles present unique challenges. The weight of an RV or trailer means standard consumer tools may be unsafe or insufficient. Additionally, many RVs require specialized tires, lifts, or towing equipment that most drivers don’t carry. For these larger vehicles, professional assistance through RV-specific roadside assistance plans is the safest and most practical choice.
Many motorhomes and towable trailers require heavy-duty towing equipment and trained operators familiar with axle configurations, weight distribution, and clearance requirements. Using improper equipment can cause additional damage, which is why specialized roadside assistance is especially important for RV travelers.
Is It Safe To Repair a Car on the Side of the Road?
In most highway situations, repairing a vehicle on the roadside is not considered safe. Even if the mechanical issue is minor, traffic speed, limited shoulder space, and distracted drivers create significant risk.
If you are stopped on a busy road, freeway, or narrow shoulder, the safest option is to remain inside your vehicle (if safely out of traffic), activate hazard lights, and request roadside assistance.
Roadside professionals use high-visibility lighting, reflective gear, and traffic awareness training to reduce risk — tools most drivers do not have.
Cost Comparison: Paying Yourself vs. Protection
Many drivers hesitate to call for help because they worry about the cost. However, on-demand roadside services in the U.S. are often significantly more expensive than an annual protection plan.
Typical Out-of-Pocket Costs
  • Local Tow (up to 10 miles): $50-$150.
  • Long-Distance Tow (50 miles or more): $200-$600 (often charged per mile).
  • RV or Large Vehicle Tow: $500-$2500+ (depending on distance, vehicle weight, terrain, and time).
  • Jump Start Service: $30-$120 (contingent upon location and time of day).
  • Lockout Service: $75-$250 (costs vary based on the complexity of the lock, location, and time of service).
  • Flat Tire Change: $25-$50 (per tire for a standard tire change).
  • Emergency Fuel Delivery: $50-$100 plus cost of fuel.
Pricing is highly unpredictable and often increases during holidays, weekends, or in rural areas where provider availability is often limited. A membership plan, like the ones offered by Good Sam Roadside Assistance, offers a predictable annual cost, helping ensure a single breakdown doesn’t disrupt your travel budget.
This is why many travelers compare roadside assistance costs with paying out of pocket ahead of time. Instead of facing uncertain emergency expenses, having roadside coverage typically provides more predictable protection. It also offers peace of mind, not just practical support.
What Happens If You Don’t Have Coverage?
Imagine you’re on a family road trip passing through a rural part of Wyoming, and your engine starts sputtering before shutting off completely. Without roadside coverage, this is what typically happens:
  • You search for nearby providers.
  • You call multiple companies to check availability.
  • You request price estimates.
  • You wait, sometimes longer than expected.
  • You pay immediately after the service.
Each step adds a layer of stress to an already stressful situation. Being prepared isn’t about expecting the worst. It’s about making sure that if something unexpected happens, it stays a minor inconvenience rather than becoming a major crisis.
Do You Really Need Roadside Assistance for Road Trips?
If you primarily drive around town, you might feel comfortable handling minor issues or calling a local friend for help. Road trips change that equation.
When you’re hundreds of miles from home, your local network disappears. You’re unfamiliar with the area, nearby service providers, and even the terrain.
Here’s why roadside assistance matters more during road trips:
  • Distance from Home: Towing a vehicle across town is manageable. Needing a tow in an unfamiliar state, far from trusted repair shops, is far more complicated.
  • Family Considerations: If you’re traveling with kids or pets, being stranded becomes a safety concern, not just an inconvenience. Getting help quickly minimizes exposure to traffic and weather.
  • Remote Highways: Many road trips involve long stretches of rural interstate or desert highway with limited cell service and few service providers. In these areas, finding help on your own can take much longer than expected.
  • RV Weight Limits: As mentioned earlier, RVs and heavy trailers require specialized equipment that most drivers don’t carry.
  • Vacation Disruption: The goal of a road trip is relaxation and adventure. Spending hours searching for a mechanic on a Sunday afternoon defeats that purpose.
Investing in roadside assistance means you get moving again quickly and can focus on the trip, not the breakdown. The farther you travel from home, the more valuable reliable roadside support becomes.
Common Misconceptions About Roadside Assistance
Several common myths prevent drivers from calling for help when they should.
Myth: Only serious accidents require assistance.
Reality: Most service calls involve “minor” issues like dead batteries and flat tires. The problem isn’t the repair itself. It’s the roadside environment where it happens.
Myth: New cars don’t break down.
Reality: New cars rely heavily on electronics. Batteries fail, tires puncture, and sensors malfunction regardless of model or year.
Myth: My car insurance covers everything.
Reality: Basic auto insurance policies typically don’t include roadside assistance; it’s an optional add-on. Even then, coverage may limit towing distance or service frequency. Comparing the detailed benefits of auto plans can help drivers choose dedicated roadside coverage designed specifically for breakdown support.
Myth: Finding a local tow is faster.
Reality: Unless you already have a trusted provider saved, finding a reputable and available company during a breakdown can be unpredictable. Established roadside assistance providers have vetted networks of professionals ready to be dispatched immediately.
How To Choose the Right Roadside Assistance Coverage
If you’ve decided that calling for help is smarter than doing it alone, the next step is choosing the right plan. Not all coverage offers the same level of protection.
Here’s what to consider:
  1. Travel Frequency: If you travel long distances often, coverage becomes more valuable. Occasional local driving presents different risks than frequent interstate travel.
  2. Vehicle Type: Do you drive a sedan, or are you towing a 40-foot camper? Ensure the plan supports the weight and size of your specific vehicle.
  3. Towing Distance: Some plans may place a mileage cap on towing services. Understand how far your roadside assistance plan will tow and look for plans that offer extended towing distances to avoid unexpected out-of-pocket costs.
  4. Nationwide Availability: Ensure a strong provider network in the regions where you travel most. Consider cross-border coverage if you visit Canada or Mexico often.
  5. Family Coverage: Does the plan cover the vehicle or the member? Many travelers prefer coverage that protects the household rather than just one car.
  6. 24/7 Dispatch Support: Breakdowns don’t follow business hours. Access to around-the-clock assistance is essential.
  7. Remote Travel Reliability: If you travel through rural or less populated areas, verify that the provider maintains strong service coverage outside major cities.
Choosing coverage isn’t about expecting breakdowns. It’s about reducing uncertainty if one happens.
Before Your Next Trip: Preventive Checklist
The best way to handle a roadside emergency is to prevent it. Use this checklist before any major trip:
  • Tire Health: Check for tread wear and make sure all tires, including the spare, are inflated to the recommended PSI. Inspect tread depth and look for bulges, cracks, or embedded objects.
  • Battery Check: Make sure terminals are clean and secure. If your battery is over three years old, consider having it load-tested at an auto parts store.
  • Fluids: Top off essential fluids, such as engine oil, coolant, and brake fluid, before departing.
  • Emergency Kit: Keep water, blankets, a flashlight, and a portable phone charger in your vehicle.
  • Route Planning: Plan remote travel routes ahead of time so you know where services, fuel stops, and populated areas are located.
  • Document Check: Confirm your roadside assistance membership is active, save the contact number in your phone, and review coverage details before departure so you know exactly what services are included.
A few minutes of preparation can reduce the chances of unexpected problems and make them easier to handle if they occur.
Final Reassurance: The Goal Isn’t Convenience — It’s Safety
Calling for roadside assistance isn’t an overreaction; it’s a smart, safety-conscious decision. Whether it’s a dead battery or a flat tire, the goal isn’t to see if you can fix it yourself. The goal is to resolve the situation safely and efficiently. Prepared travelers understand that unexpected issues are part of the journey. Having a plan doesn’t mean you expect something to go wrong. It means you’re ready if it does.
Taking a moment to compare auto and RV plans can help you choose coverage that feels right for your trips. Plan ahead, drive safely, and know that help is just a call away.
Frequently Asked Questions (FAQs)
Should I call roadside assistance for a flat tire?
Yes, especially if you are on a highway, narrow road, or uneven ground. While many drivers know how to change a tire, the risk of passing traffic makes professional assistance the safer choice. Professionals can handle it safely and quickly.
Can roadside assistance help in a parking lot?
Absolutely. Roadside assistance can be used anywhere your vehicle is disabled, including your driveway, a grocery store parking lot, or a rest area. Services like jump starts, tire changes, and lockout assistance are very common in these settings.
What if my car breaks down far from home?
This is where coverage is most valuable. Roadside assistance can tow you to the nearest qualified repair facility. Some premium plans also offer “trip interruption” benefits to help cover the cost of a hotel or rental car while your vehicle is being repaired.
Does roadside assistance work for RVs?
Yes, but you need a dedicated RV-specific plan. Standard auto coverage often excludes vehicles over a certain weight or height limit. RV-specific plans are designed to handle the unique needs of trailers, motorhomes, and campers, including heavy-duty towing.
Will insurance always cover a tow?
Not always. Many auto insurance policies only offer towing as an optional add-on with limited mileage (e.g., 5 or 10 miles). If the nearest repair facility is farther away, you may have to pay the difference out of pocket.
What happens if my car breaks down at night?
If your car breaks down at night, pull as far off the road as safely possible and turn on your hazard lights. Call for roadside assistance immediately. Professional responders use reflective gear and powerful lighting to make the scene more visible to other drivers.
