Last Updated: September 1, 2026Service
Common myths about roadside assistance debunked
Reflective warning triangle set up on the roadside behind a stopped white car on a rural road
GS
Good Sam
“Roadside assistance is one of the most misunderstood parts of car ownership. This guide tackles seven common myths and clarifies what coverage really does when you need it.”
Many drivers skip roadside assistance not because they don’t want protection, but because they misunderstand what it actually does and when it matters.
The hesitation usually isn’t about cost. It’s about assumptions. “My insurance probably covers that.” “My car is new.” “I can just call a tow truck.” “I’ve never needed it before.” These beliefs sound reasonable on the surface. But when you look closely at how breakdowns actually unfold, on highways, in unfamiliar towns, at night, or during family trips, the gap between assumption and reality becomes clear.
Let’s examine the most common roadside assistance myths and clarify what’s actually true.
Myth #1: “My Car Insurance Already Covers Roadside Help”
Reality: Insurance roadside assistance is usually limited and structured as a basic add-on, not full-service dispatch support.
Some insurance roadside coverage is structured as a reimbursement-style add-on rather than coordinated dispatch support. In practical terms, that means you may need to locate your own service provider, pay upfront, submit documentation, and then wait to be reimbursed (if the claim qualifies).
So, does insurance roadside assistance cover everything? No, it does not. Most policies include strict roadside assistance coverage limits, such as:
  • Short towing distance caps (often a fixed number of miles)
  • Limited number of service calls per year
  • Reimbursement ceilings for certain services
  • Restrictions on large vehicles or RVs
  • Availability limitations in remote areas
The towing limitation alone can become a serious issue. If you drive an RV or any other larger vehicle, many insurance policies exclude specialized towing entirely.
This is where the distinction between insurance add-ons and standalone plans becomes important. Understanding how to get roadside assistance without insurance can clarify what those alternatives look like.
Insurance treats roadside help as a minor endorsement. Dedicated roadside programs, like Good Sam Roadside Assistance, are built around dispatch networks and service coordination. The real takeaway here isn’t that insurance coverage is “bad.” It’s that it’s narrower than most drivers assume. And narrow coverage only becomes obvious when you need it.
If you want to understand what a dedicated plan includes beyond insurance add-ons, reviewing detailed plan structures helps clarify the difference in scope.
Myth #2: “I Can Just Call a Tow Truck If Something Happens”
Reality: Calling a tow truck independently is often more unpredictable, expensive, and stressful than drivers expect.
Technically, yes, you can.
But this myth relies on the belief that paying per incident is cheaper and simpler than having coverage. That assumption often ignores how breakdowns actually occur.
When your car breaks down on the highway and you start searching for help, you’re likely already under stress. It may be dark. You may be in an unfamiliar area. Your phone battery might be low. In that moment, price shopping isn’t easy.
Here’s what drivers often encounter when calling independently:
  • Unpredictable pricing based on distance and vehicle type
  • After-hours or weekend surcharges
  • Limited availability in rural areas
  • Multiple calls before finding an available provider
  • Long-distance fees that escalate quickly
You must also figure out: How much does a tow cost without coverage? The answer varies widely depending on timing, location, and vehicle type. That variability is the risk.
Realistic cost scenarios can look like this:
  • A short local tow in a metro area may cost between $40 to $300 (up to 50 miles).
  • A highway tow with mileage charges can run significantly higher.
  • Long-distance towing costs increase per mile.
  • RV towing or heavy-duty vehicle recovery can cost several hundred dollars or more, depending on conditions.
And that’s before factoring in potential second tows if the nearest facility can’t handle your repair.
The comparison between pay-per-tow and roadside membership isn’t just about dollars. It’s about predictability. You’re not negotiating pricing on the shoulder of a highway.
A driver stranded 35 miles outside the nearest town doesn’t have time to compare rates while traffic moves inches away.
Roadside emergencies are logistical problems first and financial ones second. And decisions made under stress rarely feel right.
Myth #3: “Roadside Assistance Is Only for Old Cars”
Reality: Even new vehicles experience minor issues that can leave drivers stranded.
Yes, modern vehicles are more reliable than ever. But reliability doesn’t prevent immobilization. New cars can still break down and leave drivers stranded, often for reasons unrelated to major mechanical failure.
Common causes include:
  • Battery drain from electronics
  • Flat tire from road debris
  • Key fob or electronic lockout issues
  • Overheating due to coolant problems
  • Software-related starting failures
A dead battery in an airport parking lot after a long flight is rarely about engine failure — it’s about inconvenience at the worst possible moment.
If you’ve experienced a dead battery away from home, you know how disruptive it can be, especially when the car itself is otherwise perfectly functional.
Is roadside assistance useful for new cars? Absolutely. Not because new cars are unreliable, but because minor immobilizing events still occur. A single flat tire during a road trip can derail an entire day. An electronic lockout can leave you stranded in a parking garage.
This myth persists because drivers associate roadside assistance with catastrophic breakdowns. In reality, it’s usually about small incidents that prevent mobility. And those occur far more often than major failures.
Myth #4: “I Probably Won’t Ever Need It”
Reality: Most roadside calls involve common, everyday issues — not rare catastrophes.
This belief often comes from experience: “I’ve driven for 20 years and never needed it.”
But most roadside assistance claims aren’t dramatic engine failures. They’re everyday inconveniences like:
  • Flat tires
  • Dead batteries
  • Lockouts
  • Running out of fuel
None of these events are catastrophic. But each one stops you from driving.
The real question isn’t whether you’ll face a major breakdown. It’s whether you’ll encounter an unexpected interruption that prevents you from continuing your trip.
Many roadside assistance myths stem from underestimating how often minor mobility interruptions occur. You don’t plan to misjudge fuel. You don’t plan to pick up a nail. You don’t plan for battery corrosion. But these small events are common, and they create disruption.
Preparedness doesn’t assume disaster. It prepares you for inconvenience, especially when you have family in the car.
Myth #5: “Roadside Assistance Takes Too Long To Arrive”
Reality: Response time depends more on location and conditions than on whether you call independently or use a dispatch network.
Wait times vary, just like any service, depending on location and demand. But there’s an important structural difference between organized dispatch networks and independent calls.
With a dispatch-based system, service requests move through a coordinated provider network. Location data is used to assign available assistance more efficiently than calling individual providers one by one.
Does that guarantee instant arrival? No. Several factors influence response time, including:
  • Urban vs. rural areas
  • Severe weather
  • High-demand travel periods
  • Road closures or traffic congestion
However, the assumption that roadside assistance inherently takes longer than calling independently isn’t accurate. In many cases, structured dispatch systems reduce the time spent searching for help.
If you want to understand what to expect before you ever need assistance, reviewing what to do during a roadside emergency can clarify the process and reduce uncertainty.
Response time anxiety is understandable. But coordinated systems often move more efficiently than improvised solutions.
Myth #6: “Roadside Assistance Only Covers Towing”
Reality: Towing is just one of several services included in most roadside assistance programs.
Towing is only one part of roadside assistance.
So, what other services are included in roadside assistance? While coverage varies by provider, comprehensive programs typically include:
  • Battery jump-start service
  • Tire change assistance
  • Lockout entry assistance
  • Emergency fuel delivery
  • Winching (vehicle recovery from mud, snow, or sand within specified conditions)
  • Trip interruption support (for higher-tier plans)
  • RV-specific assistance for larger vehicles
This broader scope matters because towing isn’t the most common request. Battery service and flat tire assistance are often more frequent.
If you want to compare how coverage differs between standard auto plans and plans for larger rigs like RVs, reviewing structured plan comparisons can clarify how coverage and benefits expand depending on vehicle type.
The myth persists because towing is the most visible service. In practice, everyday value often lies in the smaller services that help you continue your trip without requiring a tow.
Myth #7: “It’s Not Worth the Cost”
Reality: A single roadside incident can cost more than a year of coverage.
So, is roadside assistance worth it? The answer depends on how you evaluate risk.
Most drivers assess value based on whether they’ve needed it before. If they haven’t used it in the past, they assume they won’t in the future. But value is better measured against unpredictability.
A single tow can easily exceed the cost of a year of coverage. That doesn’t mean everyone will require a tow. It means the cost of towing without roadside assistance can vary widely and is often higher than expected.
The real comparison isn’t between “cheap” and “expensive.” It’s between:
  • Paying unpredictably during a stressful roadside event.
  • Paying predictably in advance for defined coverage.
If you’re asking yourself whether you need roadside assistance, the better question is: How disruptive would a single unexpected breakdown be for you?
For drivers who prefer structured benefits clearly outlined before deciding, reviewing the details of Good Sam’s auto plans and their benefits can provide clarity about the scope and utility.
When Roadside Assistance Makes the Biggest Difference
Roadside coverage may not look equally valuable for every driver. But certain driving patterns increase exposure to unexpected interruptions, such as:
  • Frequent road trips
  • Long daily commutes
  • Rural or remote travel
  • Families traveling with children
  • RV travelers covering multi-state routes
So, when should you get roadside assistance? The answer often correlates with how often and how far you travel away from familiar repair networks. RV travelers, in particular, face greater towing complexity due to the vehicle size. Reviewing the benefits of RV-specific plans can help you understand how heavy-duty towing differs from standard auto coverage.
Families and long-distance commuters may also place greater value on coordinated dispatch support than drivers who stay close to home. For drivers who primarily operate standard passenger vehicles, understanding how a structured car assistance service works can clarify what type of coverage best fits everyday driving needs.
While there is no universal answer to who needs roadside assistance, drivers who regularly travel longer distances, carry passengers, or drive through low-service areas often see the greatest practical benefit.
Final Takeaway: Prepared Drivers Rarely Regret It
Is roadside assistance all about expecting the worst? No, it is about reducing disruption when something minor goes wrong.
Many drivers only think about coverage after their first roadside emergency. Timely preparation reduces uncertainty, which is often what makes roadside situations stressful in the first place. Planning ahead doesn’t assume disaster. It simply makes unexpected inconveniences easier to manage.
Frequently Asked Questions (FAQs)
Is roadside assistance worth it for new cars?
Yes. Most roadside incidents involve minor mobility issues like battery drain, flat tires, or lockouts rather than major engine failure. New cars are reliable, but they are not immune to these immobilizing events.
Will roadside assistance help anywhere?
Yes. Most plans operate nationwide, but service availability depends on location and access conditions. Remote areas may affect arrival time, though structured dispatch networks typically cover most regions across the U.S.
Does roadside assistance cover flat tires?
Yes. Flat tire assistance is typically included. A technician will usually install your spare tire if you have one. Coverage specifics may vary by plan.
Can roadside assistance bring fuel?
Yes. Emergency fuel delivery is commonly included, though the cost of the fuel itself may not be included, depending on the plan and provider.
How many times can you use roadside assistance?
Usage limits vary by provider and plan. Some insurance add-ons cap service calls annually, while standalone plans outline usage allowances clearly within their coverage terms.
What if I break down at night?
Roadside assistance services generally operate 24/7. Availability may vary by region, but nighttime coverage is standard for most providers.
Does roadside assistance help RVs?
Standard auto plans may not cover RV-specific needs. Specialized RV roadside assistance plans address larger vehicle towing requirements and technical considerations.
Is insurance roadside assistance enough?
Insurance roadside assistance may be sufficient for short, local driving. However, it often includes towing distance caps, reimbursement requirements, and usage limits. Drivers who travel longer distances or operate larger vehicles typically require broader standalone coverage for consistent protection.
