Last Updated: October 16, 2026Travel Tips
What to do if your car is stuck in a ditch
Silver car stuck nose-down in a roadside ditch by a cornfield, in need of recovery at dusk
GS
Good Sam
“When your car ends up in a ditch, instinct says hit the gas and power out. But the smarter move is to stop, assess, and recover safely. Learn the steps that protect you, your car, and your wallet.”
Whether you’re driving on a slick rural road or a soft shoulder, having your car stuck in a ditch can be stressful and potentially dangerous. It usually happens when one or more wheels lose traction due to mud, snow, ice, or soft ground, preventing the vehicle from climbing safely back onto the roadway. This often happens when a vehicle slides off the road into a soft shoulder or shallow hole that reduces traction. The good news is that this is a common roadside emergency, and it can be managed with a calm, methodical approach.
Before you think about how to pull the car out, your priority should always be safety. Follow this immediate 4-step action plan if your vehicle is stuck:
  1. Turn on your hazard lights to alert other drivers.
  2. Check whether you or any passengers are injured.
  3. Move yourself and passengers to a safe location away from traffic if it is safe to exit the vehicle.
  4. Call for help if the vehicle is leaning dangerously, is in deep water, or is close to high-speed traffic.
In this guide, you’ll learn how to handle the situation safely, what you can safely try yourself, and when professional recovery is the smartest and safest option.
Immediate Safety Steps To Take When Your Car Is Stuck in a Ditch
Before stepping out to inspect the tires or assess the condition of the vehicle, focus on protecting everyone involved. A vehicle stuck off the road can shift unexpectedly, and roadside conditions can change in an instant.
  • Turn On Hazard Lights Immediately: This is the most critical step to alert other drivers and prevent a secondary collision, especially if your vehicle is partially blocking the shoulder or roadway.
  • Set the Parking Brake: Even if the vehicle feels “stuck,” soft ground or a slippery ditch can cause it to slide further. Setting the brake helps stabilize it. Make sure the vehicle is secure before stepping out to inspect it.
  • Turn Wheels Away from Traffic: If your vehicle is close to the road, turning the front wheels away from the traffic adds a layer of protection if the car is struck by another vehicle.
  • Move Passengers to Safety: If it is safe to exit, have all passengers move well away from the vehicle and traffic. If the car is on a steep incline, move to the uphill side to reduce rollover risk.
  • Call 911 If Necessary: Contact emergency services immediately if there are injuries, you suspect a fuel leak, or the vehicle’s position creates a serious hazard.
  • Do Not Attempt Recovery if the Vehicle is Unstable: If the vehicle is leaning heavily to one side or shifting, do NOT attempt to move it. Shifting weight could cause additional damage or a rollover.
What To Do if Your Car Is Stuck in a Ditch at Night
If your car gets stuck in a ditch at night, it adds layers of risk due to low visibility, changing weather, and road conditions. Use this checklist to stay safe until help arrives:
  • Keep hazard lights on at all times so approaching drivers can see you.
  • Use your interior dome light to make the vehicle cabin visible.
  • Place reflective triangles or flares 100–200 feet behind your vehicle to warn approaching drivers.
  • Wear reflective clothing if you have it in your emergency kit.
  • Stay inside the vehicle if it’s safer. On high-speed roads or in extreme weather, remaining buckled inside is often the safest choice.
Assess the Situation: Should You Try Moving the Vehicle or Call Roadside Assistance?
Once everyone is safe, you need to assess the situation carefully. Ask yourself: “Is it safe to drive out of a ditch, or should I avoid moving the car at all?” This decision can be the difference between a quick recovery and a costly repair bill. In some cases, if you are on firm ground or if the ditch is dry, things can actually work in your favor.
Decision Guide: When To Move vs. When To Call for Help
  • If the vehicle is leaning significantly or at risk of rolling: Do not attempt recovery. Call for professional help.
  • If the ditch is steep, icy, muddy, or filled with water: A professional winch-out service is recommended.
  • If traffic is nearby, creating a danger to you or others: Contact the police and roadside assistance.
  • If you see fluid leaks, suspension damage, or bent wheels: Do not drive. The car may be unsafe even if you get it out.
If you’re unsure whether to move the car or call roadside assistance, always opt for caution by reaching out for help. Remember, improper recovery attempts can cause severe frame damage, transmission failure, or personal injury. When in doubt, the safest move is to wait for the experts.
Safe Steps To Try Before Calling for Help
If the ditch is shallow, the ground is firm, and there is no visible damage, you may be able to carefully move the vehicle. However, only try this if conditions are stable and the situation appears low risk.
1. Reduce Weight
Have all passengers exit the vehicle and move to a safe distance. This lightens the load and makes it easier for the tires to gain traction. If another driver stops to help, coordinate carefully and keep everyone clear of moving vehicles.
2. Clear a Path Around the Tires
Remove loose snow, mud, or debris so the tire can grip the surface. Ensure the tailpipe is not obstructed by snow or mud to prevent carbon monoxide buildup.
3. Use Traction Aids
Place a traction device in front of the drive tires. This can be a sandbag, kitty litter, dedicated traction boards, or even a flat piece of cardboard from your trunk. These materials can provide extra traction and help get the wheels moving.
4. Try Gentle Rocking
Shift slowly between “Drive” and “Reverse” while gently pressing the gas pedal to create momentum. Don’t slam on the gas; if you accelerate suddenly, it can cause the tires to spin and dig deeper. Excessive spinning can damage tires, overheat components, or dig the car deeper.
5. Stop Immediately If Traction Doesn’t Improve
If the wheels continue to spin without progress or the vehicle starts to shift sideways, stop and reassess.
Critical Safety Warnings:
  • Never stand between vehicles during a recovery attempt.
  • Never attach tow straps to bumpers, axles, or suspension components. Tow straps should only be attached to manufacturer-approved recovery points.
  • Never attempt to pull a car out of a ditch unless you know the proper frame attachment points.
Improper recovery can cause serious injury or permanent vehicle damage. If you are unsure which recovery method or tool to use, it is safer to call for help.
When To Call a Professional Recovery or Tow Service
There is a point where continued attempts can make the situation worse. If you cannot safely move the vehicle or the conditions look unstable from the start, it is time to call in the experts.
Professional recovery is the safer choice when:
  • The vehicle is stuck at a sharp angle.
  • The car is in deep mud, heavy snow, or on a steep embankment.
  • There is visible damage to the body or mechanical components.
  • The vehicle is stuck too deep to move without proper recovery equipment.
  • Weather conditions are severe, or visibility is poor.
Professional auto services use rated winches, controlled pull angles, and proper recovery points. This precision prevents frame stress and other damage that commonly occurs during improper recovery attempts.
Winch-Out vs. Tow: Which Service Do You Need?
When you call for help, you may be asked if you need a winch-out or a tow. Knowing the difference helps dispatch the right equipment quickly and avoid unnecessary delays.
  • Winch-Out: A short-distance pull using a motorized cable to get a vehicle back onto a stable, drivable surface. This is typically the right service when a car is stuck in a ditch but otherwise appears undamaged and safe to drive.
  • Tow: Transporting the vehicle on a truck to a repair facility. A tow is required if the vehicle has damage, flat tires, or mechanical issues that make it unsafe to drive.
You can review the benefits of your roadside assistance membership to see how your plan handles winch-outs, towing, and other roadside assistance services to better understand which service you need.
Who Should You Call When Your Car Is Stuck in a Ditch?
Call 911 If:
  • There are injuries.
  • You smell fuel or see fluid leaks.
  • The vehicle is blocking traffic.
  • There is an immediate risk of collision.
Call Roadside Assistance If:
  • The vehicle is stuck but appears undamaged.
  • You need a professional winch-out service.
  • You feel unsafe attempting recovery.
  • You need help changing a flat tire or addressing a dead battery that occurred during the incident.
What To Say When You Call
When contacting roadside assistance or emergency services, have this information ready so responders can reach you quickly:
  • Exact Location: GPS coordinates, mile markers, nearby exits, or landmarks.
  • Vehicle Type: Make, model, color, and license plate.
  • Vehicle Condition: Leaning, stuck in mud, damaged, or blocking traffic.
  • Weather Conditions: Ice, snow, heavy rain, or low visibility.
Dispatchers use this information to send the right equipment and to prevent delayed assistance.
Safety Checks Before You Drive Away
If you, or a professional, successfully pull the car out of a ditch, don’t drive away immediately. Being stuck can strain components or cause hidden damage, so a quick inspection is important.
  1. Check for Fluid Leaks: Look under the car for oil, coolant, or brake fluid.
  2. Test the Steering: Ensure the wheel feels centered and the car does not pull to one side.
  3. Listen for Unusual Sounds: Grinding, clicking, or thumping noises can indicate damage.
  4. Inspect the Tires: Check for mud packed into the rims (which causes vibration), cuts, or sidewall damage.
  5. Test the Brakes: Ensure they feel firm and responsive before returning to normal driving.
If you notice vibration, pulling, or anything unusual, drive slowly to the nearest service station for inspection. If a tire was damaged during the incident, carefully change the flat before resuming your journey.
Safe Steps for Night, Snow, and Severe Weather Recovery
Severe weather can turn a simple recovery into a dangerous roadside situation. If you find yourself stuck during snow, rain, or poor visibility, take extra precautions:
  • Stay Visible: Clear snow or mud away from your lights and keep your hazard lights on so other drivers can see you.
  • Avoid Overexertion: Shoveling or pushing in extreme cold can lead to exhaustion, hypothermia, or medical emergencies. Work in short bursts or wait for professional recovery.
  • Clear the Exhaust Pipe: If you run the engine for heat, ensure the exhaust pipe is completely clear. A blocked pipe can cause dangerous carbon monoxide buildup inside the vehicle.
  • Conserve Fuel: Run the engine for only about 10 minutes every hour to stay warm while preserving fuel and battery life. Ensure the exhaust pipe is completely clear of snow, mud, or debris before running the engine.
How Much Does It Cost To Get a Car Out of a Ditch?
The cost of a professional winch or tow service can vary, but knowing the average can help you make informed decisions.
In the United States, a standard winch-out and tow service typically ranges from $40 to $300 (up to 50 miles). The factors that affect the cost include:
  • Time of Day: After-hours, weekend, or holiday services often cost more.
  • Complexity: A simple pull from a shallow ditch costs less than a recovery from deep mud or snow requiring specialized rigging.
  • Recovery difficulty: The angle of the car, how deep the wheels are buried, and how far it sits from the road can affect the final cost.
  • Distance: Travel fees may apply if you are in a remote location.
If you have a roadside assistance plan (through your auto insurance or independent membership, like those offered by Good Sam), it can significantly reduce or eliminate out-of-pocket costs for these services.
How Roadside Assistance Can Help When Your Car Is Stuck
When your vehicle is stuck, having access to reliable roadside assistance can make recovery faster and safer. Professional services typically provide:
  • Expert Winch-Out Services: Trained operators who know how to recover your vehicle without causing further damage.
  • Towing if Needed: Seamless transition from recovery to transport if your car is undrivable.
  • 24/7 Dispatch: Support is available anytime, day or night, across the U.S.
  • Comprehensive Coverage: Coverage applies to your vehicle during common roadside situations, including winch-outs, towing, and other emergency assistance when needed.
Having support ready before an emergency happens can reduce stress, prevent costly mistakes, and help you get back on the road safely.
Emergency Kit Checklist for Future Trips
The best way to handle a vehicle stuck in a ditch is to be prepared before it happens. Every driver should carry an emergency kit that includes:
  • Reflective triangles or flares to alert other drivers.
  • Traction boards or a bag of sand/kitty litter for extra traction.
  • A rated tow strap (only for use by someone who knows how to attach it properly).
  • A high-quality flashlight with extra batteries.
  • A reflective safety vest.
  • A first aid kit.
  • A portable phone charger so you can call for help if needed.
Keeping these items together in one kit ensures you always have the right tool available when you need it. Preparation is especially important during winter weather or when driving in rural areas where assistance may take longer to arrive.
Conclusion
Whether it’s a car stuck in a ditch during the day or a vehicle off the road at night, the priority remains the same: safety first, assessment second, recovery third. While small steps like clearing debris or using traction aids can sometimes help, attempting to move a vehicle too aggressively can increase the risks of damage or personal injury.
In many situations, calling a professional roadside recovery service is the safest choice. It protects your vehicle and, more importantly, helps ensure you and your passengers get back on the road safely.
Ready to drive with more confidence? Explore Good Sam Roadside Assistance plans today and enjoy the peace of mind that help is always just a phone call away.
Frequently Asked Questions (FAQs)
Can you drive out of a ditch safely?
It depends on the depth of the ditch, ground firmness, and the angle of the car. If the ditch is shallow and the tires can gain traction, you may be able to drive out slowly. However, if the car is leaning, sliding, or the wheels are spinning, you should stop to avoid damage and call for assistance.
How long does a winch-out take?
Once the recovery professional arrives, most standard winch-outs take about 15 to 30 minutes, depending on the vehicle’s position and how complex the pull is.
Does roadside assistance cover ditch recovery?
Most comprehensive roadside assistance plans, like those from Good Sam, include winch-out services. Coverage may be limited based on the distance from a paved road, terrain conditions, or the equipment required.
Will insurance pay for ditch recovery?
If the incident involves a covered accident, your policy may help pay for recovery. For non-accident situations where a vehicle is simply stuck, roadside assistance is typically used instead.
What is a winch-out service?
A winch-out service uses a motorized winch and high-strength cable to pull a stuck vehicle out of mud, snow, or a ditch and back onto a stable, drivable surface.
