Last Updated: August 27, 2026Travel Tips
What to do if you have a tire blowout
Shredded blown-out tire lying on a dry roadside shoulder as a white SUV passes by
GS
Good Sam
“A tire blowout can happen in an instant, but how you react makes all the difference. Learn how to stay in control, pull over safely, and know when to call for help.”
A tire blowout is a sudden loss of air pressure, often marked by a loud pop, heavy vibration, or a sharp pull from the affected tire. It can feel alarming, especially at highway speeds, but understanding the right emergency response can help you stay in control and avoid serious accidents.
The key is simple. Stay calm, keep the vehicle steady, and guide your vehicle safely to the shoulder. Once you’re safe, Good Sam Roadside Assistance can handle the tire change or tow, so you can focus on getting back to your trip.
Immediate Action Steps
When a tire blows out, your first few seconds are critical. You need to focus on control and avoid sudden movements.
If you experience a tire blowout:
  1. Grip the steering wheel firmly with both hands: This helps you counteract the sudden pull to one side.
  2. Do NOT slam on the brakes: Sudden braking shifts weight abruptly and can lead to loss of control and balance.
  3. Maintain control and gradually ease off the accelerator: Allow the vehicle to slow naturally by gently lifting your foot off the gas once you have stabilized the steering.
  4. Keep steering straight: Stay in your lane and focus on maintaining control until the vehicle stabilizes.
  5. Gradually ease off the gas: Allow the vehicle to slow naturally instead of forcing it to stop.
  6. Signal and move toward the shoulder: Once you have slowed to a safe speed (below 30 mph), steer the vehicle toward a flat area away from traffic.
What Does a Tire Blowout Feel Like?
Recognizing the signs of a tire blowout helps you react quickly and more confidently to maintain control. Most drivers notice a combination of sound, movement, and handling changes.
The Sound
  • A loud bang or explosive pop as the tire ruptures instantly. Drivers often mistake it for a gunshot or engine backfire.
The Feel
  • A sudden, violent pull to one side, especially with a front-tire failure.
  • Steering wheel vibration caused by the damaged tire flapping against the road surface.
  • Reduced stability, making the car feel shaky, heavy, or difficult to control.
The Noise
  • Repetitive thumping or flapping sounds as the damaged tire strikes the pavement or wheel well with each rotation.
Key Note: A slow leak develops gradually. A blowout is immediate and forceful, leaving little time to react.
How To Pull Over Safely After a Tire Blowout
Once you’ve regained control, your priority is getting off the road without creating additional danger.
  • Turn on hazard lights immediately to alert surrounding traffic.
  • Allow the vehicle to slow naturally avoid hard braking.
  • Steer toward the right shoulder when possible. This provides more space from high-speed traffic.
  • Choose flat, stable ground. Avoid curves, hills, or soft dirt where footing or equipment (like a jack) could slip.
  • Engage the parking brake once fully stopped on stable ground.
After you’re safely off the road, take a moment to assess the situation before deciding your next steps.
Pro Tip: On busy interstates, stay inside the vehicle with your seatbelt fastened and doors locked until help arrives. Only exit if you can reach a protected area like behind a guardrail.
What To Do After You Stop
You’re safely off the road. Now, take a breath and focus on visibility and personal safety.
  • Assess traffic conditions before exiting the vehicle. Check mirrors and wait for a safe gap.
  • Remain inside if traffic is heavy, visibility is poor (night, rain, fog), or conditions feel unsafe.
  • Place reflective triangles or flares 10–20 feet behind your vehicle if it is safe to do so.
  • Inspect the damaged tire only if it’s clearly safe to approach. Look for severe damage, shredded rubber, or rim contact.
  • Decide whether changing the tire is practical or if calling for professional help is the safer option.
If the situation appears to be a gradual loss of air rather than a sudden blowout, you may need a different approach to address the flat tire.
When Should You Call Roadside Assistance?
A tire blowout can be overwhelming, and knowing when to call roadside assistance can help prevent a stressful situation from becoming dangerous. In many cases, professional assistance is the safest option.
Call roadside assistance immediately if:
  • You’re on a busy interstate or highway.
  • It’s nighttime, or visibility is low.
  • Traffic conditions feel unsafe.
  • You don’t have a spare tire.
  • You’re driving a large SUV, truck, trailer, or RV.
  • The vehicle feels unstable after stopping.
You may be able to change the tire yourself if:
  • You’re in a low-traffic, well-lit area.
  • You have proper tools and a usable spare.
  • You feel physically safe performing the task.
When in doubt, it’s always safer to call for help. Good Sam offers auto and RV roadside assistance plans, so help is always available no matter the type of vehicle you are driving.
Front Tire vs. Rear Tire Blowout: Is There a Difference?
Yes. The location of the blowout changes how the vehicle reacts, even though the core response remains the same.
Front Tire Blowout
  • Affects Steering Control Directly: The steering wheel may pull hard toward the damaged side.
  • Feels More Violent: The front tires handle steering and much of the braking load, so the impact is immediate and aggressive.
  • Requires a Firm Grip: You will need to keep the steering wheel straight and avoid overcorrecting.
Rear Tire Blowout
  • Affects Stability and Balance: The back end may sway, wobble, or fishtail, especially at higher speeds.
  • Less Steering Disruption: The wheel may not pull as hard, but the car will feel loose or sliding.
  • Needs Gentle Corrections: Small, smooth steering adjustments help stabilize the car. Oversteering or sudden movements can make it worse.
What Causes a Tire Blowout?
Most tire blowouts, while they feel sudden, are not always random. They result from stress, damage, or heat buildup over time, especially during sustained highway driving.
Underinflated Tires
Low tire pressure is one of the leading causes of blowouts. Underinflated tires flex more as they roll, generating excess heat that weakens the tire’s structure and increases failure risk at high speeds.
A Tire Pressure Monitoring System (TPMS) can alert you when pressure drops, but regular manual pressure checks are still important.
Overloaded Vehicles
Exceeding a tire’s load rating puts added strain on the rubber and internal belts. This is more common in SUVs, trucks, trailers, and RVs carrying heavy cargo or towing.
Worn or Aging Tires
Tires with low tread, sidewall cracks, bulges, or advanced age are more prone to failure. Even tires that look fine can degrade internally over time, making sudden blowouts more likely.
Road Hazards (Potholes or Debris)
Striking potholes, sharp debris, or curbs can cause immediate damage or weaken a tire, which can lead to a blowout later, sometimes miles down the road.
Extreme Heat and Highway Driving
A tire blowout in hot weather is more common during summer road trips. Hot pavement combined with sustained highway speeds increases internal tire temperatures, especially when tires are underinflated or overloaded.
Manufacturing Defects (Rare Cases)
Although uncommon, materials or construction defects can cause unexpected tire failure, even on newer tires.
Many blowouts are preventable with proper tire inflation, load management, and routine inspections. But understanding what roadside assistance typically covers can help you decide whether to request on-site service or towing.
What Should You Not Do During a Tire Blowout?
Panic responses can worsen a blowout and turn a recoverable situation into a crash. Avoid these common mistakes:
  • Do not brake aggressively. It can lock wheels and lead to skidding or spinning.
  • Do not jerk the steering wheel. Sudden moves amplify pull or sway.
  • Do not overcorrect. Sharp adjustments may cause fishtailing or loss of control.
  • Do not panic accelerate. Sudden and excess throttle can make the vehicle harder to control.
Staying calm and taking smooth, deliberate steps gives you the best chance to regain control safely.
How To Prevent a Tire Blowout
Most tire blowouts are preventable with basic maintenance and regular checks. A few simple habits can help significantly reduce your risk before you hit the road.
  • Check tire pressure monthly and before long trips. Don’t ignore TPMS warnings.
  • Rotate tires at recommended intervals to promote even wear.
  • Replace tires every 6 to 10 years, even if tread appears acceptable.
  • Monitor tread depth and watch for cracks, bulges, or uneven wear patterns.
  • Avoid exceeding the vehicle’s load capacity, especially when hauling or towing.
  • Inspect tires before long drives for visible damage or low pressure.
Get Help Quickly After a Tire Blowout
After a tire blowout, safety must come before speed. If traffic is heavy, visibility is poor, or the tire is severely damaged, attempting a roadside fix can put you at risk. When there’s any doubt, professional assistance is often the safer option.
Good Sam Roadside Assistance offers 24/7 support to help drivers handle blowouts safely, whether that means a tire change using your spare or towing your vehicle to the nearest qualified repair facility. Knowing how far towing can take you is also important, especially during long trips or highway travel.
You can also take a moment to review Good Sam’s coverage options and compare auto plans and RV plans to find the right coverage for your driving needs, so you know you have the right support in place before your next trip.
Frequently Asked Questions (FAQs)
What should you do if you have a tire blowout?
Stay calm and focus on control. Grip the steering wheel firmly, ease off the accelerator without braking hard, and guide the vehicle to the right shoulder with hazard lights on. Once stopped safely, assess the situation and call for help if needed.
Is it better to brake or accelerate during a blowout?
Avoid aggressive braking or acceleration. Focus on control and allow the vehicle to slow gradually.
How far can you drive on a blown tire?
Ideally, you shouldn’t continue driving beyond what is necessary to reach a safe stopping point. Continuing to drive risks damage to the wheels, suspension, and brakes.
Is a tire blowout covered by roadside assistance?
Yes. Roadside assistance typically covers tire changes using your spare or towing if the tire cannot be safely replaced on-site.
Does car insurance cover tire blowouts?
Standard auto insurance policies usually do not cover tire damage caused by wear or road hazards. Roadside assistance can help fill this gap, especially for RV owners who might need specialized services like RV towing.
