Last Updated: August 13, 2026Service
Why your car overheats in the summer & what to do about it
Man inspecting the steaming open hood of a silver SUV on a roadside, with his dog watching from the window.
GS
Good Sam
“Summer heat can push any engine to its limit. Knowing the warning signs, what to do in the moment, and when to call for help can keep an overheated car from becoming an expensive problem.”
Imagine you’re cruising down a sun-baked highway or crawling through stop-and-go summer traffic when it happens. The temperature gauge on your dashboard starts creeping toward the red, or a dreaded warning light illuminates your dashboard. In that moment, a wave of anxiety hits. Your car is overheating, and suddenly, a simple drive becomes a stressful roadside emergency, especially under the relentless summer sun.
You’re not alone. Car overheating in summer is one of the most common reasons drivers experience a breakdown. High temperatures, heavy traffic, and long drives can quickly push your engine past safe operating limits and turn planned trips and daily commutes into daunting situations. But knowledge is power, and the right help is just a call away. Understanding why a car begins to overheat and knowing what to do can help you stay safe and avoid costly repairs.
This guide walks you through the common reasons cars overheat, the steps to take when your engine temperature rises, and, most importantly, how a reliable roadside assistance plan can be your savior on the hot asphalt.
Why Is My Car Overheating in the Summer?
Summer puts added strain on a car’s cooling system. While a well-maintained car should tolerate warm weather, high temperatures and summer driving can push it past its limits. These often lead to overheating, especially when multiple stressors occur at once.
Here are the most common summer-specific factors that can cause your engine to overheat:
  • Extreme Outside Temperatures: Ambient heat makes it harder for your radiator to release heat from the engine. When it’s 95°F outside, the cooling system must work much harder to keep the engine at a safe operating temperature than on a 75°F day.
  • Stop-and-Go Traffic: When you’re stuck in traffic, airflow through the radiator reduces. Without sufficient airflow, heat builds up rapidly under the hood, and the engine can overheat.
  • Long Highway Drives: Extended driving at high speeds generates excess heat. If there’s a hidden issue in the coolant system, a long road trip is often when it reveals itself.
  • Heavy Loads: A packed car, roof rack, or towing a trailer forces the engine to work harder, producing more heat and raising overall engine temperature.
  • Constant A/C Usage: Air conditioning puts additional strain on the engine, and the A/C condenser, which sits in front of the radiator, can slightly reduce radiator airflow and lower cooling efficiency.
Common Reasons That Can Cause a Car To Overheat
Beyond the summer heat, mechanical issues within the car’s cooling system are usually the root cause when an overheated car breaks down. Understanding these common reasons can help you explain the issue clearly when you call for help.
Low Coolant Levels
Low coolant level is the most common cause of engine overheating. Coolant (a combination of water and antifreeze) absorbs engine heat and carries it to the radiator. When levels drop, the engine cannot regulate heat effectively.
Common causes of low coolant levels include:
  • Coolant Leaks: Leaks may occur in coolant hoses, the radiator, the water pump, or the heater core.
  • Old or Contaminated Coolant: Over time, coolant breaks down and loses its ability to regulate temperature and maintain proper coolant flow.
Radiator Issues
The radiator’s job is to release heat from the coolant. Radiator issues reduce its ability to cool the engine, which can quickly cause overheating.
The common issues affecting radiator efficiency include:
  • Blocked Fins: Bugs, debris, and road grime can create a blockage in the exterior fins that restricts airflow.
  • Internal Corrosion: Rust and scale buildup inside the radiator can disrupt the flow of coolant.
Thermostat Failure
A thermostat regulates coolant circulation based on engine temperature. Thermostat failure can prevent coolant from reaching the radiator, causing immediate overheating.
Broken Water Pump
The water pump’s role is to circulate coolant throughout the engine and radiator. A failed pump means no coolant circulating through the system, leading to rapid overheating.
Radiator Fan Malfunction
Whether electric or belt-driven, the radiator fan pulls air through the radiator at low speeds or when the vehicle is idling to regulate engine temperature. A fan malfunction often leads to overheating in traffic or while stopped.
Blown Head Gasket
A damaged head gasket is a serious and costly problem. It can allow exhaust gases into the cooling system or coolant into the engine oil, leading to persistent overheating and serious engine damage.
5 Signs Your Engine Is Overheated
Recognizing the early engine overheating signs can help you act before permanent damage occurs:
  1. Temperature Gauge in the Red Zone: A clear signal to keep an eye on the temperature gauge.
  2. Steam or Smoke Coming from Hood: Often appears as white, sweet-smelling vapor coming from the engine area.
  3. Burning Smell: This could indicate leaking coolant or oil hitting hot engine parts.
  4. Engine Knocking Sound: Also called “pinging,” caused by excess heat affecting combustion.
  5. Dashboard Warning Lights: Temperature or check engine warning lights (often a red thermometer) indicating the engine may be overheating.
What To Do When Your Engine Overheats on the Road
SAFETY FIRST: Do not continue driving. Driving an overheating car, even for a short distance, can lead to serious engine damage and costly repairs.
Follow these steps as soon as it’s safe to do so:
  1. Turn off the A/C: This reduces engine load. If needed, turn the heater to full blast. While uncomfortable, it can help pull heat away from the engine and allow it to cool slightly.
  2. Pull Over to a Safe Location: Get completely off the road onto the shoulder, a parking lot, or a side street. Turn on your hazard lights and stop as soon as it’s safe.
  3. Shut Off the Engine: This stops additional heat from building. You may open the hood to allow heat to escape, but do not lean over or touch the extremely hot engine components.
  4. Wait 15–30 Minutes for Cooling: Be patient and wait for the engine to cool for at least 15-30 minutes. Do not attempt to touch anything under the hood immediately.
  5. Do NOT Open the Radiator Cap: The cooling system is under extreme pressure. Opening the hood immediately and removing the radiator cap can cause scalding coolant to spray out.
  6. Check Coolant Level (Only If Safe): Once the vehicle has cooled, carefully check the coolant reservoir (not the radiator itself). If it’s empty, you’re likely dealing with a leak.
At this point, your next step matters. If you are not 100% confident in diagnosing the issue or making a safe temporary fix, it’s time to stop and call for professional help. Knowing what to do if you need emergency roadside assistance can make the process faster, safer, and far less stressful while you wait for help to arrive.
Can Roadside Assistance Help With an Overheated Car?
Absolutely. This is exactly the type of emergency roadside assistance services are designed for. A service like Good Sam Roadside Assistance can help you manage the situation and prevent further damage.
Roadside assistance may offer:
  • Emergency Towing: If the engine cannot cool properly, they will tow your car to a nearby service facility to prevent additional engine damage.
  • Coolant Top-Up (If Safe): If the issue is simply low coolant levels and there’s no major leak, a technician may add coolant to help you reach a mechanic safely.
  • Battery and Radiator Fan Checks: They can assess basic electrical issues to identify whether a failed radiator fan or an electrical issue is contributing to overheating.
  • Minor Hose Repairs: In some cases, a temporary fix might be applied to a leaking hose to allow a safe, short drive to a service center.
  • Flatbed Transport: For certain vehicles or severe overheating cases, a flatbed tow truck ensures no further strain on the drivetrain.
  • Lockout Assistance (If Needed): Overheating can cause flustered mistakes. If you accidentally lock your keys in the car during the crisis, they can help with that, too.
It’s important to understand the limits of roadside assistance. A technician cannot perform major repairs like replacing a water pump or head gasket on the roadside. Their goal is to manage the emergency, reduce risk, and get you and your vehicle to safety. Understanding what roadside assistance typically includes can help set the right expectations when you’re dealing with an overheated car and deciding on the safest next step.
When Should You Call Roadside Assistance for an Overheated Car?
Call for help immediately if:
  • Your car continues to overheat repeatedly after cooling down.
  • Steam or smoke continues to billow out even after the engine has cooled.
  • You see visible coolant leaks under the car (often green, red, or orange puddles).
  • The temperature gauge won’t go down even after pulling over.
  • You’re stranded in an unfamiliar or unsafe area, far from a mechanic.
Benefits of Roadside Assistance for Overheating Emergencies
Having roadside coverage isn’t just about the tow; it’s about peace of mind during a stressful, time-sensitive situation.
Key benefits of roadside coverage include:
  • 24/7 Availability: Breakdowns don’t keep business hours. Help is available day or night, on weekends and holidays.
  • Professional Safety: Trained technicians handle the dangerous aspects involving hot engines, traffic exposure, and heavy equipment.
  • Prevents Engine Damage: Prompt assistance and a quick tow can prevent serious engine damage that may result from continuing to drive an overheated vehicle.
  • Saves Major Towing Cost: Paying out-of-pocket for a long-distance tow can be incredibly expensive. Coverage helps avoid such unexpected expenses.
  • Avoids Unsafe Roadside Repairs: No need to risk injury trying to attempt temporary fixes near moving traffic or hot engine components.
  • Peace of Mind: Knowing who to call is half the battle. You can focus on staying safe instead of scrambling for help.
Explore the full range of auto plan benefits that provide this essential safety net during overheating emergencies.
Can You Drive with an Overheated Engine?
The short and critical answer is: No.
Driving an overheating car, even for “just a mile,” is incredibly dangerous for your vehicle. The extreme heat can quickly cause internal engine components to fail and lead to costly repairs or worsen engine damage.
Major risks include:
  • Warped Cylinder Head: Repairs often cost thousands of dollars.
  • Blown Head Gasket: A complex and labor-intensive fix.
  • Total Engine Seizure: This often means a complete engine replacement, the most expensive car repair possible.
There is no safe distance to drive with an overheated engine. Your safest and most cost-effective move is to stop and call for assistance.
How To Prevent Your Car From Overheating in Summer
Proactive maintenance is your best defense to avoid overheating and breakdown during summer driving:
  • Check Coolant Levels Monthly: Ensure the overflow tank sits between the minimum and maximum marks when the engine is cool.
  • Replace Old Coolant: Follow the recommended interval by your vehicle manufacturer (typically every 30,000-60,000 miles).
  • Flush the Cooling System Regularly: This removes corrosive buildup that can restrict coolant flow.
  • Inspect Belts and Hoses: Look for cracks, bulges, or brittleness, signs of worn-out materials, before summer hits.
  • Replace a Faulty Thermostat: A sticking thermostat can prevent proper temperature regulation, so replace it preventatively.
  • Check the Radiator Cap: A weak cap won’t hold pressure, reducing cooling efficiency.
  • Park in Shaded Areas: Reduce the thermal load on your cooling system before you even start.
  • Schedule Regular Servicing: Routine maintenance and regular inspections by professionals can help you spot small issues and reduce the risk of breakdowns.
Why Summer Road Trips Increase the Risk of Overheating
Your vacation plans and summer road trips check all the boxes that can quickly push a vehicle toward overheating:
  • Long Drives: Sustained engine operation generates continuous heat over extended periods.
  • Loaded Vehicles: Cars packed with passengers, luggage, and gear force the engine to work harder.
  • High RPM Driving: Mountain climbs, steep grades, or long highway stretches increase engine strain.
  • Desert Climates: Extremely high ambient temperatures make it harder for the cooling system to regulate heat.
Together, these significantly increase the risk of an overheated engine. Ensuring your cooling system is in top shape and having a roadside plan is non-negotiable for summer travel. And just as important is knowing exactly how to use roadside assistance if trouble arises.
How Good Sam Roadside Assistance Helps
When you’re facing down an overheated car on a road trip, you need a partner you can trust. Good Sam Roadside Assistance is designed to provide help wherever the road takes you.
With Good Sam Roadside Assistance, your coverage includes:
  • Nationwide Coverage: Wherever your summer adventures take you in the U.S., help is nearby.
  • Towing: Unlimited towing to the nearest qualified repair facility when driving is unsafe.
  • Emergency Services: From fuel delivery to tire changes, we’re there for a wide range of breakdowns.
  • 24/7 Support: Our around-the-clock dispatch and a network of vetted service providers ensure you’re never truly stranded.
We encourage you to compare our auto plans to find the coverage that fits your driving habits and gives you confidence all season long.
Final Thoughts
An overheating car in summer is more than an inconvenience; it’s a threat to your safety and your wallet. By understanding what causes overheating, acting calmly and safely when it happens, and having a strong roadside assistance plan, you can turn a potential crisis into a manageable situation.
Summer should be about making memories, not dealing with breakdowns. Prioritize your cooling system maintenance and invest in the peace of mind that comes with knowing expert help is always just a phone call away. Don’t wait for the temperature gauge to spike. Prepare before you hit the road this summer!
Frequently Asked Questions (FAQs)
What should I do if my car starts overheating while driving?
Immediately turn off the A/C, turn the heater to high (to help draw heat away), and safely pull over as soon as possible. Shut off the engine and call for assistance.
Can I pour water on my overheated engine?
No. Pouring water on a hot engine can cause rapid thermal contraction, cracking critical components like the engine block or cylinder head. It also creates dangerous steam. Always let the engine cool naturally.
How long should I wait before driving again?
Even if the temperature appears normal after cooling or adding coolant, drive directly to a mechanic for inspection. Do not resume a long trip until the underlying issue is diagnosed.
Will roadside assistance fix overheating on the spot?
Sometimes, for minor issues like a coolant top-off or a loose hose clamp. In many cases, the safest and only option is towing the vehicle to a repair facility. The technician’s primary goal is to prevent further damage to your engine and ensure your safety.
What happens if I ignore overheating?
Continued driving will almost certainly lead to severe and permanent engine damage, such as a warped cylinder head or blown head gasket. The repair cost can escalate from hundreds to thousands of dollars very quickly. Always stop and address the issue.
