Last Updated: August 4, 2026Service
What is unlimited towing and why does it matter for RV and auto drivers?
Red flatbed tow truck loading a dark sedan onto its tilted bed outside an auto repair shop
GS
Good Sam
“Breakdowns rarely happen near the right repair shop. Unlimited towing removes the mileage cap, and Go Anywhere lets you choose your destination — so distance doesn't decide your day.”
A breakdown rarely happens at a convenient time. Typically, it’s not when you’re pulling into your driveway on a quiet Sunday afternoon. It’s far more likely to happen halfway through a family road trip, on a remote stretch of highway, or while towing an RV miles away from the nearest town. In those moments, the real stress isn’t just about what broke, but how long it will take to get help.
For many drivers, that’s where frustration with traditional roadside assistance begins. You call for help, only to learn your plan caps towing at 5, 20, or maybe 100 miles. That might sound generous on paper, until you realize the nearest capable repair facility, or RV service center, is well beyond that limit. The rest of the tow comes out of your pocket, often at hundreds of dollars per hour.
Unlimited towing changes the equation. Instead of counting miles or worrying about distance limits, unlimited towing roadside assistance removes the mileage cap altogether. Your vehicle is towed to the nearest qualified service center, no matter how far away it is. For RV owners navigating remote routes and everyday drivers who don’t want financial surprises during a breakdown, that difference matters more than most people realize.
Here’s what unlimited towing really means, how it works, where its limits still exist, and why pairing it with destination flexibility, like a Go Anywhere option, can make all the difference.
What Is Unlimited Towing?
Unlimited towing means there is no mileage cap on how far your vehicle can be towed after a breakdown. The nearest appropriate repair facility could be 15 miles away or 250 miles away.
That said, unlimited towing doesn’t mean unlimited freedom by default. Most roadside assistance plans with unlimited towing are structured around a specific rule: your vehicle will be transported to the nearest qualified service center. This ensures safety, faster resolution, and proper handling, which is especially important for RVs, trailers, and modern vehicles that require specialized equipment.
Additionally, unlimited towing refers specifically to distance, not cost structure. Most plans include a maximum service benefit per disablement. In rare cases where a tow is exceptionally long or complex, charges beyond that benefit limit could apply.
It’s also important to clarify what unlimited towing does not include. It doesn’t usually allow unlimited destination choice, and it doesn’t mean unlimited service calls per year. Plans still have usage limits, eligibility requirements, and coverage guidelines. The word “unlimited” refers specifically to towing distance, not frequency or destination.
How Unlimited Towing Works
When a breakdown happens, unlimited towing follows a straightforward process designed to get you moving again as quickly and efficiently as possible.
  1. First, you contact your roadside assistance provider and share your location and situation.
  2. The provider identifies the nearest qualified service center that can properly handle your vehicle.
  3. Once the destination is confirmed, a tow truck with the appropriate capacity and setup is dispatched based on your vehicle type.
  4. Your vehicle is then transported without mileage-based charges, removing guesswork, surprise fees, and the pressure to make rushed decisions on the side of the road.
What “Nearest Qualified Service Center” Means
The nearest qualified service center isn’t just the closest repair shop on a map. It refers to a facility that meets specific standards, including:
  • Certified technicians with the right expertise
  • Proper tools and equipment for your vehicle
  • RV-capable infrastructure when towing motorhomes, fifth wheels, or travel trailers
For large RVs or specialized vehicles, this often means bypassing smaller shops in favor of RV service centers that could be farther away but properly equipped. This approach helps avoid improper repairs, repeat tows, and unnecessary delays.
Unlimited towing prioritizes a safe resolution over proximity, which is especially valuable when you’re already dealing with an unexpected breakdown.
What Is the Go Anywhere Option?
While unlimited towing removes mileage limits, some drivers want more control over where their vehicle ends up. That’s where the Go Anywhere option comes into play. The key difference is control. Standard unlimited towing prioritizes proximity and capability. Unlimited towing with Go Anywhere adds personal preference to the mix.
The Go Anywhere feature allows towing to a destination of your choice within 100 miles of the disablement location, rather than being limited to the nearest qualified service center. This could mean your preferred mechanic, a specific dealership, your home, or even back to a campground if you’re traveling in an RV.
This added flexibility is particularly valuable for drivers who already have trusted service relationships or for RV owners who prefer repairs at familiar facilities. Long-term travelers, full-time RVers, and drivers with custom or modified vehicles often find that Go Anywhere turns a stressful breakdown into a manageable inconvenience.
Limited Towing vs. Unlimited Towing vs. Unlimited Towing + Go Anywhere
To understand the real value of unlimited towing, it helps to compare it directly with limited towing plans. The biggest differences come down to how far your vehicle will actually be towed, who absorbs the cost beyond that distance, and how much say you have in where your vehicle ends up.
Limited towing plans are built around mileage caps. Unlimited towing removes that ceiling. And when destination flexibility is added through options like Go Anywhere, the difference becomes even more meaningful, especially for RV owners, long-distance travelers, and anyone who drives outside dense metro areas.
Limited Towing
  • Towing Distance: Fixed mileage cap (typically 5-100 miles)
  • Who Pays Beyond the Limit: Driver pays out of pocket for excess miles
  • Tow Destination: Nearest repair facility within mileage limit
  • Destination Flexibility: Very low
  • Cost Predictability: Low, costs can escalate quickly
  • Suitability for Short Trips: Local driving, urban areas
  • Suitability for Long-Distance Travel: Poor fit
  • RV and Heavy Vehicle Suitability: Often insufficient
  • Risk in Remote Areas: High (mileage limits reached quickly)
  • Peace of Mind: Limited
Unlimited Towing
  • Towing Distance: No mileage limit
  • Who Pays Beyond the Limit: Covered by the plan
  • Tow Destination: Nearest qualified service center
  • Destination Flexibility: Moderate
  • Cost Predictability: High, no distance-based surprises
  • Suitability for Short Trips: Yes
  • Suitability for Long-Distance Travel:  Strong fit
  • RV and Heavy Vehicle Suitability: Much better
  • Risk in Remote Areas: Low
  • Peace of Mind: Strong
  • Tow Destination: Destination of the driver’s choice (up to 100 miles)
  • Destination Flexibility: High
  • Cost Predictability: Highest, no distance or destination-based surprises
  • Suitability for Long-Distance Travel: Excellent fit
  • RV and Heavy Vehicle Suitability: Best
  • Risk in Remote Areas: Lowest
  • Peace of Mind: Maximum
Why It Matters for RV Drivers
RV breakdowns come with unique challenges. These vehicles are heavier, longer, and more complex than standard cars. Not every tow truck can handle them, and not every repair shop is equipped to service them.
Unlimited towing for RV drivers ensures that when something goes wrong, you’re not forced into a partial tow or an unsuitable facility just because it’s closer. Instead, your RV is taken to a service center that can actually diagnose and fix the problem.
For RV travelers exploring remote parks, desert highways, or cross-country routes, that convenience is invaluable. Adding Go Anywhere coverage allows for even more flexibility. It could mean towing back to a familiar dealership, a trusted service facility, or safely back to a campground while waiting for parts.
Why It Matters for Auto Drivers
For everyday auto drivers, breakdowns rarely happen near the “right” repair shop. Longer commutes, urban sprawl, and increasingly complex vehicles that require specialized diagnostics make towing distance more than a technical detail. It directly shapes how quickly and affordably you get back on the road.
Limited towing plans often direct drivers to the closest available shop, regardless of whether that shop services your vehicle type, honors your warranty, or has the right diagnostic tools. The result is often a second tow, delays while parts are sourced, or repairs you didn’t plan for simply because you felt stuck in the moment.
Unlimited towing roadside assistance removes those constraints by allowing your vehicle to be taken to the nearest qualified service center, one equipped to handle your car properly, not just conveniently. That distinction matters for modern vehicles with advanced electronics, hybrid systems, or manufacturer-specific service requirements.
When paired with Go Anywhere flexibility, the value increases further. Instead of being forced into an unfamiliar shop during a stressful breakdown, drivers can choose to tow their vehicle to a trusted local mechanic, a dealership they already work with, or even their home. For families, commuters, and anyone relying on their car day in and day out, that control translates into fewer rushed choices, lower long-term repair costs, and a far less disruptive breakdown experience.
Choosing the Right Unlimited Roadside Plan
When evaluating options, it’s important to look beyond the headline promise. Consider whether the plan covers RVs as well as standard vehicles, how many service calls are allowed per year, and whether destination flexibility is included or available as an add-on.
Coverage area matters too, especially if you travel across state lines or spend time in remote regions. Additional benefits like trip interruption coverage, fuel delivery, or lockout assistance may also factor into which plan offers the best overall value and whether roadside assistance is worth the cost, depending on how you travel.
Myths About Unlimited Towing
One common misconception is that unlimited towing allows you to tow your RV or vehicle anywhere by default. In reality, standard unlimited towing typically takes you to the nearest qualified service center. Destination choice typically requires an upgrade, like the Go Anywhere option.
Another myth is that unlimited towing means unlimited usage. Most plans still have annual service call limits, so it’s important to understand how many calls are covered within a given year.
Reviewing the details of their RV plan or auto plan and clearing up these misunderstandings helps drivers choose coverage that actually aligns with their expectations and travel habits.
Real-Life Scenarios
Imagine an RV breakdown in a sparsely populated area. A limited towing plan might cover only part of the distance to an RV-capable service center, leaving the rest as a costly out-of-pocket expense. Unlimited towing removes that uncertainty by eliminating mileage caps altogether.
Or consider a family car that breaks down late at night. With unlimited towing and Go Anywhere, the vehicle can be taken home safely instead of sitting overnight at an unfamiliar repair shop.
These real-world situations highlight where unlimited towing and recovery provide real value, not just on paper, but when drivers need help the most.
Conclusion: Distance Shouldn’t Decide Your Safety
Unlimited towing is less about luxury and more about predictability, safety, and control when things go wrong. Whether you drive an RV across long distances or rely on your car for everyday travel, removing mileage limits means fewer financial surprises and better outcomes during stressful situations.
For drivers who want even greater flexibility, pairing unlimited towing with a Go Anywhere option ensures that not only distance, but destination, works in your favor.
If convenience and security on the road matter to you, comparing RV or auto roadside assistance plans with unlimited towing is a smart place to start.
Frequently Asked Questions (FAQs)
What does “nearest qualified service center” mean?
It refers to the closest facility equipped to safely and properly repair your vehicle, not just the closest shop on the map.
Can I choose where my car is towed?
With standard unlimited towing, the destination is the nearest qualified facility. Choosing a specific destination typically requires a Go Anywhere option.
Does unlimited towing cover breakdowns in remote areas?
Unlimited towing usually means there is no set mileage limit per tow. However, most plans have a maximum service cap per disablement. If recovery or towing costs exceed that cap, there may be out-of-pocket expenses, especially in remote areas. Always review your plan details to understand coverage limits. Can I use unlimited towing multiple times in a year?
Most plans allow multiple service calls per year, though limits vary by provider.
Does unlimited towing include roadside repairs?
It usually includes basic roadside assistance, while major repairs are handled at the service center.
Does unlimited towing apply after an accident?
Coverage depends on the plan, but many roadside assistance policies include post-accident towing.
