Last Updated: September 8, 2026Towing
10 signs your vehicle needs to be towed
Red tow truck's wheel-lift arm hooking up the front wheel of a black car for towing
GS
Good Sam
“Knowing when to call for a tow can save your vehicle, your wallet, and your safety. Learn the warning signs that say it's time to stop driving and arrange professional help.”
Unexpected problems can happen to any driver. A sudden noise, a strange smell, or a glowing dashboard light can leave you unsure about what to do next. When you’re on a tight schedule, sometimes with your family in tow, it’s tempting to keep driving “just a few more miles” to find a shop.
In moments like these, choosing safety over convenience is the best thing you can do to protect both your vehicle and your passengers. Continuing to drive while your car or motorhome is signaling for help can turn a minor fix into a major mechanical failure. When in doubt, choosing caution can help prevent more costly repairs and reduce the risk of a dangerous roadside situation.
Warnings Your Vehicle May Need a Tow
If you’re still unsure after the guidance above, look for these warning patterns. The more you notice at once, the safer it is to stop driving and arrange a tow.
  • Warning signs appear suddenly and get worse within minutes.
  • The vehicle feels unsafe to control or unpredictable.
  • A dashboard warning light is flashing instead of steady.
  • You smell burning, hot coolant, or strong fuel odors.
  • The vehicle struggles to accelerate or maintain speed.
  • You hear new loud mechanical noises that weren’t present earlier.
  • You see fluid actively dripping or pooling under the vehicle.
  • The vehicle behaves differently than it did earlier in the trip.
If multiple symptoms appear together, continuing to drive increases the risk of breakdown or accident.
When Does a Vehicle Need Towing?
A vehicle needs towing when it cannot be safely driven under its own power, or when continuing to drive increases the risk of mechanical failure, loss of control, or a secondary accident.
In general, towing is necessary if your vehicle:
  • Cannot Move Safely: The engine won’t stay running, or the wheels won’t turn.
  • Has Lost Braking or Steering Control: These systems are essential for safe operation.
  • Is Overheating Repeatedly: Excessive heat is one of the fastest ways to damage the engine.
  • Is Leaking Significant Fluids: Fluids are critical to nearly every vehicle system.
  • Has Sustained Collision Damage: Even minor impacts can compromise structural components and affect safe operation.
If you find yourself in any of these situations, knowing the next steps can reduce stress and keep you safe while you arrange assistance. Understanding what to do if you need emergency roadside assistance helps ensure you respond calmly and correctly.
Why Continuing To Drive Can Cause Severe Damage
Trying to “push through” vehicle trouble to save time or money often has the opposite effect. Driving with the engine overheating, brake issues, or transmission problems can turn a manageable issue into a major repair.
  • Overheating can lead to engine seizure. Extreme heat can warp metal components inside the engine, leading to failure that often requires full replacement.
  • Low oil or fluid levels can cause engine failure. Without proper lubrication and cooling, metal parts grind against each other, causing irreversible internal damage.
  • Transmission slipping can require full replacement. Heat buildup from slipping gears can damage the transmission, often beyond repair.
  • Brake damage can spread to rotors and calipers. Driving on worn brake pads can result in damage to expensive braking components.
  • Suspension damage can reduce control. Broken suspension parts can affect vehicle handling and stability.
Addressing these warning signs early and arranging a tow can help prevent further damage and keep the situation from becoming more expensive or dangerous.
10 Common Signs Your Vehicle Needs Towing
Knowing when to tow a car comes down to recognizing these warning signs early and acting quickly before the problem worsens.
1. Engine Overheating
If your temperature gauge creeps into the red zone or you see steam (often smelling like maple syrup) coming from the hood, pull over immediately. Driving farther only adds stress to the engine.
Continuing to operate an overheating vehicle risks warped components, a blown head gasket, or even a cracked engine block. Shut off the engine and arrange a tow.
2. Smoke Coming from the Engine
Smoke from the engine bay is never normal, and the color can offer clues:
  • White smoke may indicate coolant burning, often linked to a head gasket issue.
  • Blue smoke may signal oil burning.
  • Black smoke may point to a fuel system problem.
Any smoke creates a potential fire risk. Pull over, turn off the engine, and call for help. Do not open the hood if you suspect a fire hazard.
3. Stalling or Loss of Power While Driving
If your car stalls at a stoplight or suddenly loses power while moving, it can create a serious traffic hazard. Common causes may include alternator failure, fuel delivery issues, or electrical problems.
If the vehicle won’t restart or repeatedly loses power, pull over safely and call for a tow. Continued driving can be unpredictable and dangerous.
4. Loud Knocking, Grinding, or Screeching Noises
A rhythmic knocking sound often signals internal engine trouble, while screeching may indicate a failing belt or water pump. Grinding during gear shifts often points to transmission issues.
These noises usually worsen quickly. Stop driving and arrange for professional towing to prevent further damage.
5. Brake Failure or Grinding Brakes
A soft or spongy brake pedal, pulling while braking, or grinding noises indicate compromised braking. Grinding usually means metal-on-metal contact in the braking system.
This is a clear sign the vehicle should be towed. Do not drive with reduced stopping ability.
6. Steering Failure or Loss of Power Steering
If the steering wheel suddenly becomes extremely difficult to turn, a belt or power steering component may have failed. In larger vehicles, this can severely limit your ability to control direction safely.
Pull over carefully and call for a tow.
7. Severe Vibrations or Shaking at Highway Speeds
Strong or sudden shaking can signal tire separation, axle damage, or loose lug nuts. If it becomes hard to keep the vehicle in its lane, treat it as a safety issue.
Slow down gradually, move to a safe location, and have the vehicle towed.
8. Flashing Check Engine Light
A flashing check engine light signals an urgent engine issue, often a severe engine misfire that can cause rapid damage if ignored.
Pull over when it’s safe, turn off the engine, and arrange for a tow.
9. Major Fluid Leaks Under the Vehicle
A small amount of clear water from A/C condensation is normal. Coolant, oil, transmission fluid, or brake fluid leaks are not.
If you notice a growing puddle, especially of brake fluid, coolant, or transmission fluid, shut off the engine and call for a tow.
10. Transmission Slipping or Refusing to Shift
If engine RPM increases without corresponding acceleration, or gear changes feel delayed or erratic, the transmission may be failing.
This can make highway driving and intersections unsafe. Stop driving and arrange a tow to prevent further damage.
Special Considerations for RVs and Motorhomes
RVs and motorhomes present unique challenges due to their size, weight, and complex mechanical systems. Brake controllers, heavy-duty suspension components, and specialized tires mean standard towing equipment often isn’t sufficient. Not all roadside plans cover large motorhomes, which makes RV-specific coverage important.
Breakdowns involving RVs typically require professional operators with specialized towing equipment designed to handle larger vehicles safely. Reviewing RV towing services and understanding coverage differences by plan can help ensure your rig is handled safely. If you travel regularly, it’s also helpful to compare RV plans so you are prepared before an issue occurs.
Should You Drive or Request a Tow? Quick Safety Decision Guide
When you’re unsure whether to continue driving, use this simple guide to make a safer decision:
  • Vehicle cannot move under its own power? Tow immediately.
  • Braking or steering compromised? Do not drive.
  • Overheating persists after 15 minutes of cooling? Do not continue driving.
  • A jump-start worked, and the vehicle runs normally? A short drive to the service center may be safe if no warning lights remain illuminated, but monitor closely.
  • Large fluid leaks visible (bigger than a dinner plate)? Shut the engine off and tow.
  • Multiple warning lights are flashing? Stop and assess; this can indicate a serious problem.
If you’re asking yourself, “is it safe to drive my car?” Remember that the safest choice prevents both injury and additional damage. Understanding how far roadside assistance will tow your vehicle can help set expectations about where your vehicle will be taken when you call for a tow.
What To Do if You Need a Tow
If you’ve identified problems that require towing, follow these steps to keep you and your passengers safe:
  • Pull safely onto the shoulder. Get as far from moving traffic as possible.
  • Turn on hazard lights. Make your vehicle visible to other drivers and the tow operator.
  • Stay inside the vehicle. On busy highways, the safest place is often inside with your seatbelt on, unless there’s a fire risk.
  • Call for help. Contact your roadside assistance provider immediately.
  • Be specific with the location. Provide mile markers, exit numbers, nearby landmarks, or GPS coordinates.
Good Sam offers 24/7 nationwide auto and RV roadside assistance coverage, so drivers can get help when they need it, whether at home or on the road.
When You May Not Need a Tow
Not every roadside situation requires a tow. Many issues can be resolved safely on the spot:
  • Dead Battery: If a jump-start works and the battery holds a charge, you can usually drive to have it tested.
  • Flat Tire: With a properly inflated spare, a technician can install it so you can continue to a repair facility. Remember, most spares are intended for temporary use.
  • Lockout: Locksmith services can help get you back inside without towing.
  • Out of Fuel: Fuel delivery can provide enough gas to reach the nearest station.
Reviewing the benefits and service caps of your plan can help you understand which services may be available beyond towing and which plan best fits your needs, especially when you compare your options.
Final Thoughts
In a stressful moment, it’s natural to worry about the inconvenience or cost of a tow. But safety should always come first. Recognizing the signs your vehicle needs towing helps you act early, before a manageable problem becomes a dangerous one.
Preparing in advance can make unexpected breakdowns easier to handle. Whether you drive a car, SUV, truck, or motorhome, having reliable roadside protection can turn an unexpected disruption into a temporary setback. Good Sam offers roadside assistance plans with 24/7 nationwide support for a range of vehicles.
Remember, your vehicle can be repaired. Your safety is what matters most.
Frequently Asked Questions (FAQs)
Can I drive my car if it’s overheating?
No. Even short distances can cause severe engine damage. Pull over, turn off the engine, and arrange a tow if overheating persists.
What happens if I drive with a flashing check engine light?
A flashing light signals an urgent problem that can cause permanent engine or exhaust system damage. Pull over when safe and have the vehicle towed.
How much does a tow cost?
Towing costs vary based on distance and vehicle type. Without coverage, fees can add up quickly, which is why roadside assistance plans can help prevent unexpected expenses.
Does insurance cover towing?
Some insurance policies cover towing after an accident, but mechanical breakdowns typically require separate roadside assistance coverage.
How far will roadside assistance tow my vehicle?
Towing distance depends on the details of your plan. Some plans limit mileage, while others offer extended or unlimited towing to the nearest qualified service center.
Should I tow my RV if it breaks down on the highway?
Yes. Due to its size and complexity, driving a disabled RV increases the risk of loss of control or further damage. Professional towing is typically the safest option.
