Last Updated: May 26, 2026Maintenance
RV spring and summer maintenance checklist
An RV parked in the distance in a campground. There are large yellow and orange daffodils blooming from the ground due to Spring.
GS
Good Sam
“Get your RV good to go for spring and summer! This checklist helps you trade potential headaches for smooth travels. These maintenance tips save ensure your rig is primed and ready for every adventure ahead.”
After months of sitting in storage, your RV needs a little TLC before hitting the road. Think of spring as your rig's annual wake-up call. Whether you're planning weekend getaways or cross-country adventures, a solid RV spring maintenance checklist helps you keep your travels safe, saves money, and prevents the dreaded roadside breakdowns.
The winter months can take a real toll on RVs. Cold temperatures drain batteries, create flat spots on tires, and cause seals to dry out and crack. Without proper RV spring maintenance, these hidden problems can turn your dream vacation into a mechanical nightmare. The good news? A few hours of preventive care now can mean months of worry-free travel when the camping season begins.
This guide walks you through everything you need to get your RV ready for the first trip of the season, from roof inspections and tire checks to flushing the water system. You'll learn what to inspect, how to approach basic maintenance, and when to call in the pros. And remember, even with careful preparation, unexpected issues can still happen. That's when Good Sam Roadside Assistance provides 24/7 support with unlimited towing to the nearest qualified service center to help you get back on track.
Quick RV Spring & Summer Maintenance Checklist
Keep your RV road-ready throughout spring and summer with this quick reference guide.
Checklist for Both Seasons
  • Check engine oil and transmission fluid
  • Inspect belts and hoses
  • Test all lights
  • Update emergency kit supplies
  • Verify insurance and roadside coverage
  • Perform monthly inspections
Spring Checklist
  • Inspect roof seals for winter damage
  • Deep clean the exterior and apply wax
  • De-winterize plumbing system
  • Sanitize the water system thoroughly
  • Recharge or replace batteries
  • Check the propane system and fill tanks
  • Test all safety detectors
  • Lubricate slide-outs and other moving parts
  • Inspect awnings for mold or damage
Summer Checklist
  • Monitor tire pressure weekly
  • Clean A/C filters monthly
  • Inspect exterior surfaces for sun damage
  • Lubricate hinges and mechanisms
  • Check generator oil levels
  • Inspect water hoses for swelling or leaks
  • Monitor waste tanks closely
  • Clean refrigerator vents
Why RV Spring Maintenance Matters
Have you ever pulled your RV out of storage only to discover problems that could have been prevented? You're not alone. Understanding the importance of RV maintenance starts with knowing what winter does to your rig while it sits unused.
Winter Storage Typically Creates Four Major Problem Areas
  1. Batteries lose charge naturally, often dropping below 50%. This damages internal cells and shortens battery life by years, not months.
  2. Tires develop flat spots where they rest against the ground. Your RV's weight presses on the same section for months, creating permanent deformities that cause vibration and uneven wear.
  3. Rubber seals around windows and doors contract in cold temperatures, developing cracks that allow moisture intrusion and leaks.
  4. Rodents seek shelter, chewing through wiring and nesting inside the furnace, cabinets, and water heater.
Temperature Swings Add Another Layer of Risk
Plumbing systems can suffer when trapped water freezes despite winterization efforts. As water expands, even small amounts can crack pipes and fittings.
Electrical connections are also vulnerable, as condensation leads to corrosion, shorts, and intermittent failures.
Over time, freeze-thaw cycles reduce the flexibility of roof membranes, door gaskets, and slide-out seals, increasing the chances of tears when you open slide-outs or extend awnings.
Post-winter RV damage can compound quickly when ignored. A small roof leak can saturate insulation and rot framing. Corroded battery terminals can drain your electrical system without warning. These cascading failures can sideline your RV for months, not days.
The benefits of spring RV maintenance make the effort worthwhile. Preventive care helps catch a small seal problem before it turns into expensive water damage. Regular inspections reduce the likelihood of roadside emergencies that leave families stranded far from help. Most importantly, proactive RV maintenance helps you avoid breakdowns during the peak camping season, when repair shops are booked solid for weeks.
Pre-Maintenance Preparation
Before diving into your RV inspection checklist, gather the right RV maintenance tools and supplies. Think of this as setting up your workspace. Having everything ready helps save time, prevents interruptions, and keeps your workflow efficient.
Essential RV maintenance supplies to keep on hand include:
  • Digital tire pressure gauge
  • Portable air compressor
  • RV-safe soap and cleaning brushes
  • Sealant and caulk for repairs
  • Battery charger or maintainer
  • Water hose and sanitizing solution
  • Protective gloves and safety glasses
  • Flashlight for dark compartments and cabinets
  • Basic hand tools
Safety should always come first during any RV pre-trip inspection. When inspecting your RV:
  • Park on level ground to ensure accurate readings.
  • Chock your wheels to prevent rolling, even with the parking brake engaged.
  • Disconnect from shore power before touching electrical components.
  • Turn off the propane at the tank before checking gas lines or propane appliances.
These simple precautions take only a few minutes but prevent serious accidents.
Once you've completed safety prep, it's time to inspect your RV systematically. A detailed pre-trip inspection checklist helps you move from one system to the next without missing critical areas, setting the stage for a smooth transition into the full RV spring and summer maintenance checklists that follow.
RV Spring Maintenance Checklist
This comprehensive checklist covers every major system that needs attention after winter storage. Work through each area methodically to ensure your RV is truly road-ready.
Exterior Inspection and Spring Cleaning
Start your RV roof inspection by accessing the roof safely. Look for cracks, soft spots, or bubbling that may signal hidden water damage. Check all penetrations around vents, antennas, and air conditioner units.
Inspect sealant along every seam, window frame, and door edge. Run your finger along joints to feel for gaps. Corners and transition points, where surfaces meet, often fail first, so pay extra attention there. Don't forget window weep holes, which drain moisture but can clog with debris.
Wash your RV from top to bottom using RV-safe soap to remove road grime, tree sap, and other environmental contaminants. Once clean, apply protective wax to fiberglass surfaces for UV protection.
Extend the RV awnings fully and inspect for mold, tears, or damaged hardware. Clean the awning thoroughly and let it dry completely before retracting.
Tires and Suspension
Check RV tire pressure when the tires are cold, using manufacturer-recommended PSI. Perform a tire tread check using the quarter test: insert a quarter into the tread with Washington's head facing down. If you see the top of his head, replace the tire. Inspect sidewalls for cracks, bulges, or bubbles. Confirm tire age using the DOT code. Tires older than five years need professional inspection, and most require replacement after seven years regardless of tread.
Torque lug nuts to factory specs and inspect suspension components for signs of wear, rust, or damage. Grease all Zerk fittings if your chassis is equipped with them. And don't forget your spare tire is mounted, inflated, and in good working condition.
Battery and Electrical System
Recharge or replace batteries that no longer hold a charge. Clean corrosion from battery terminals using a wire brush and a baking soda solution. Test your generator under load for 30 minutes. Verify your power converter is working properly and test all interior and exterior lights. Electrical issues rank among the most common RV problems, making a thorough inspection essential at this stage.
Plumbing and Water System
De-winterize your plumbing by flushing antifreeze from all water lines. Sanitize your fresh water tank using a bleach solution (one-quarter cup of bleach per 15 gallons of water), then flush the system thoroughly. Check the anode rod in your water heater and replace it if it's corroded. Test the water pump and pressurize the system, checking all faucets, toilets, and connections for leaks.
Propane and Safety Systems
Check propane tank levels and refill as needed. Inspect LP gas hoses for cracks, brittleness, or wear. Perform a leak test on all connections using soapy water and watch for bubbles. Test smoke detectors, carbon monoxide detectors, and propane detectors. Replace batteries annually and units when their expiration dates are approaching. Check your fire extinguisher's pressure gauge to ensure it's in working order.
Slide-Outs and Seals
Extend all slide-outs and clean the tracks thoroughly to remove dirt and debris. Lubricate moving parts per the manufacturer's instructions. Inspect rubber seals for cracks, separation, or drying, and apply seal conditioner to keep the rubber flexible and weather resistant.
Summer RV Maintenance Checklist
Once the camping season begins, RV summer maintenance helps keep your rig running through hot weather. Summer travel places extra strain on cooling systems, tires, and mechanical components, making regular inspections essential.
HVAC and Cooling
RV hot weather maintenance starts with the air conditioner. Clean or replace A/C filters monthly to maintain airflow and efficiency. Test the cooling output to ensure the system is performing properly. Clear all vents of dust and debris. Check coils for dirt build-up that can restrict airflow and reduce cooling efficiency.
Heat and Sun Protection
Extended sun exposure accelerates UV damage. Inspect surfaces for fading, cracking, or peeling. Reapply protective wax every few months during peak summer. Check the roof sealant regularly, as heat can cause it to expand, opening gaps that can lead to leaks.
Mechanical Checks
Summer maintenance extends beyond cooling systems. Monitor tire pressure weekly, as heat causes air pressure to rise. Inspect brakes before and after long trips. Check engine fluids, including oil, coolant, and transmission fluid, more frequently. Run your generator monthly to keep its internal components lubricated and reliable.
Plumbing and Tanks
High temperatures affect plumbing components. Inspect water hoses for swelling or soft spots. Monitor black and gray holding tanks carefully during heavy use. Flush tanks regularly to prevent build-up and odors. Consider tank treatments designed for temperatures above 85 degrees.
Interior Care
Check refrigerator vents for obstructions that can affect cooling performance. Inspect window shades and coverings that block heat. Monitor humidity levels inside your RV, as excess moisture and condensation can lead to mold. Use moisture absorbers or added ventilation as needed to keep the interior comfortable.
Even with consistent RV maintenance, unexpected breakdowns can still happen. That's why you need RV roadside coverage for comprehensive protection, reliable assistance ensures stress-free summer travels.
RV Maintenance Tips for Long Trips
Extended trips demand extra preparation beyond a standard RV maintenance checklist. Long-distance travel puts sustained stress on your rig, making proactive planning essential.
Before you take your RV on a long journey:
  • Schedule a professional inspection to catch issues that simple checks might miss.
  • Carry spare fluids, including engine oil, coolant, and transmission fluid.
  • Keep a portable tire inflator onboard for pressure adjustments on the road.
  • Monitor dashboard warnings and address alerts immediately.
  • Track service history in a maintenance log to identify recurring issues.
  • Pack an emergency roadside kit with flares, reflective triangles, flashlights, basic tools, and jumper cables.
  • Verify your roadside assistance coverage is active before departure.
These steps help ensure your RV stays reliable when you are far from home and reduce the chance of a trip-ending breakdown.
When To Visit a Professional
Some RV issues require professional expertise and specialized tools. Knowing when to stop trying to fix the issue yourself and call a professional can prevent costly repairs and safety risks.
Seek professional help if you notice:
  • Burning smells
  • Unexplained fluid leaks
  • A/C failure
  • Unusual brake noise or vibration
These warning signs often indicate problems that worsen quickly without proper diagnosis.
  • Professional services are also recommended for:
  • Brake inspections and repairs
  • Wheel alignment and chassis inspection
  • Generator maintenance and servicing
  • Annual propane leak-down tests, which must be performed by certified professionals.
Working with trained professionals ensures these critical systems are handled safely and correctly.
Hit the Road With Confidence
A thorough RV spring and summer maintenance checklist helps catch small issues before they become major emergencies. From roof inspections to tire checks, each task protects your investment and ensures safer travel. Regular RV spring maintenance gives you peace of mind knowing your RV is in top shape when you're miles from home.
Even with careful preparation, unexpected issues can still arise. That's where Good Sam Roadside Assistance helps bridge the gap between a minor inconvenience and a trip-ending disaster. With 24/7 support, unlimited towing to the nearest qualified service center, and comprehensive nationwide coverage, you're never left stranded.
Use this guide to get your RV ready for the road and travel confidently knowing you've taken the right steps to protect your family, your rig and your plans. Your next adventure awaits.
Frequently Asked Questions
How often should I perform RV spring maintenance?
Complete a full RV spring maintenance check annually after winter storage. If you use your RV year-round, perform comprehensive inspections every six months with monthly system checks during the active travel season.
What maintenance can I skip?
Never skip safety-critical tasks like brake inspections, tire checks, propane system tests, or detector testing. You can defer cosmetic work like waxing, but structural and mechanical maintenance protects your safety and prevents expensive repairs.
Can I do RV maintenance myself?
You can handle many tasks like cleaning, inspecting seals, checking tire pressure, and testing lights. However, brake work, propane system repairs, electrical troubleshooting, and generator service require professional expertise. Know your limits and hire certified technicians when needed.
How do I maintain my RV in summer heat?
To maintain your RV in summer heat:
  • Monitor tire pressure weekly, as heat increases air pressure.
  • Clean A/C filters monthly.
  • Check coolant levels frequently.
  • Inspect hoses for heat damage.
  • Keep your fresh water tank full to prevent pump damage.
  • Park in shade when possible and use awnings to reduce interior temperatures.
