Fifth wheel towing: Setup, safety and roadside assistance guide
Good Sam
“Towing a fifth wheel safely starts with the right truck and a hitching routine you never skip. When something still goes wrong, an RV roadside plan that covers both your truck and trailer gets your whole rig moving again.”
Picture a loaded fifth wheel on a two-lane highway, 60 miles from the nearest town, when a trailer tire lets go. Or the truck’s engine quits with a 40-foot trailer still hitched to the bed. A standard car tow truck can’t help with either one.
Fifth wheels tow with more stability than most bumper-pull trailers, which is why so many RVers choose them. But their size, weight and in-bed hitch mean the setup, the driving and the breakdowns all work differently.
This guide covers what you need to tow a fifth wheel, how to hitch and unhitch it, the problems that most often stop owners on the road, and how to choose fifth wheel roadside assistance that covers your whole rig.
What Is Fifth Wheel Roadside Assistance?
Roadside assistance for a fifth wheel RV isn’t the same as what you’d get for a typical car or even a smaller RV. While there’s some overlap, like towing, battery jump-starts, and lockout services, the size, weight, and complexity of fifth wheels raise the stakes significantly.
Imagine getting a flat tire on a rural highway. Standard car roadside assistance likely won’t send a heavy-duty tow truck or a technician trained to handle RV-specific hitch systems. That can mean longer delays, added stress, and, sometimes, out-of-pocket expenses.
On the other hand, fifth wheel roadside assistance typically covers:
- Towing for your fifth wheel and tow vehicle to the nearest qualified service center. With Good Sam, there’s no distance limit, even if that’s hundreds of miles away.
- Flat and spare tire service to fix, purchase or replace a damaged tire.
- Battery service to jump-start your truck wherever you are.
- Lockout service if your keys are locked inside.
- Emergency fuel and fluids: up to 5 gallons of fuel delivered to get you to a gas station. You pay for the fuel.
- Winching or extraction if you’re stuck in mud, sand or snow.
The biggest difference is that an RV plan accounts for both halves of your rig. A car-only plan may cover your truck but not the 35- or 40-foot trailer hitched to it. One thing to know up front: Good Sam’s Standard RV plan doesn’t cover fifth wheels. You’ll need Platinum, Platinum Complete or Platinum+.
How Fifth Wheel Towing Works
A fifth wheel connects inside the bed of a pickup truck, not at the rear bumper. A steel kingpin under the trailer’s front overhang (the pin box) drops into a horseshoe-shaped hitch plate mounted over or just ahead of the truck’s rear axle. Jaws inside the hitch close around the kingpin and lock it in place.
Because the trailer’s weight sits over the rear axle instead of behind the bumper, fifth wheels are more resistant to sway and crosswinds than most bumper-pull travel trailers. Part of the trailer also rides above the truck bed, so the overall rig is shorter than a travel trailer with the same living space.
That in-bed connection is also why fifth wheel breakdowns need different equipment. A tow operator has to account for the truck, the trailer and the hitch between them.
What You Need to Tow a Fifth Wheel
Fifth wheels require a pickup truck, and not every pickup can handle one. Before you buy a trailer or hitch up for the first time, check these three things.
Truck Requirements
- Towing capacity: Your truck’s tow rating should meet or exceed the fifth wheel’s GVWR, its maximum loaded weight, not its dry weight.
- Payload capacity: The trailer’s pin weight sits in your truck bed and counts against payload, along with passengers and gear. Find your payload on the driver’s door jamb sticker.
- Bed length: A long bed (about 8 feet) gives the trailer’s front cap room to clear the cab in tight turns. Short-bed trucks usually need a sliding hitch.
- Trailer brake controller: Required to operate the fifth wheel’s electric brakes from the cab.
- Mounting system: Many newer trucks have a factory puck system for drop-in hitches. Others need aftermarket rails.
Fifth Wheel Weight Terms To Know
- GVWR (Gross Vehicle Weight Rating): The maximum loaded weight of the truck or trailer, set by the manufacturer.
- GCWR (Gross Combined Weight Rating): The maximum weight of the loaded truck and loaded trailer together.
- GTW (Gross Trailer Weight): What your trailer actually weighs fully loaded.
- Pin weight: The downward force the kingpin puts on the hitch in your truck bed. It’s the fifth wheel version of tongue weight.
Fifth Wheel Hitch Types
- Fixed hitch: Mounts in one position over the rear axle. Simple and stable; best for long-bed trucks.
- Sliding hitch: Moves the kingpin rearward during tight turns to keep the trailer from hitting the cab. Common on short-bed trucks.
- Puck system (OEM) hitch: Drops into factory mounting points in the truck bed and removes easily when you need your bed back.
Roadside tip: Write down your truck and trailer’s weights, length and height in addition to the year, make, and model of each. Dispatch uses these to send a tow truck that can handle your rig.
How To Hitch and Unhitch a Fifth Wheel
Most hitch-related roadside calls trace back to a skipped step. Follow the same routine every time, even after hundreds of hookups.
How To Hitch a Fifth Wheel
- Line up the truck. Back up straight toward the kingpin with a spotter or backup camera.
- Lower the tailgate and set the height. Use the landing gear to raise or lower the trailer until the kingpin sits slightly below the top of the hitch plate.
- Back in slowly. Keep the wheels straight until the kingpin slides into the hitch and the jaws close.
- Confirm the lock. Look at the jaws, check the handle position, and insert the safety pin or clip. Many owners do a gentle pull test in low gear.
- Connect the breakaway cable to the truck, not the hitch. Check state rules on safety chains.
- Plug in the 7-way connector and test brake lights, turn signals and the trailer brakes from the cab.
- Raise the landing gear fully and retract any rear stabilizers.
- Close the tailgate and do a walk-around. Check the jaws, pin, cable, wiring, jacks, tires and lights.
How To Unhitch a Fifth Wheel
- Park on level, solid ground and chock the trailer tires on both sides.
- Lower the tailgate.
- Lower the landing gear until the pads touch the ground (use pads or blocks on soft surfaces), then take a bit of weight off the hitch.
- Unplug the 7-way connector and breakaway cable.
- Pull the safety pin and open the hitch handle.
- Raise the front of the trailer slightly to take pressure off the jaws, then slowly pull the truck forward.
- Level the trailer before setting up camp.
Always follow your hitch manufacturer’s instructions, since steps vary by model.
Hitching Mistakes That Lead To Roadside Calls
- Jaws not fully locked or safety pin missing. This is the main cause of trailer separation.
- Tailgate left down. It can hit the trailer’s front cap on turns or grades.
- No brake test. Without working trailer brakes, the truck’s brakes do all the stopping.
- Hitching on uneven ground. This can bind the kingpin and make unhitching difficult later.
- Landing gear not fully raised. It can scrape or snag on driveways and dips.
Common Roadside Problems Fifth Wheel Owners Face
When you tow a fifth wheel, you’re managing a lot more than just your truck. There are several points where things can go wrong.
Here are some of the most common roadside issues fifth wheel owners face:
1. Tire Blowouts
Fifth wheels are heavy, especially when fully loaded, making tire blowouts one of the most frequent (and dangerous) issues on the road. A blowout at highway speeds can cause serious damage to your trailer’s sidewalls or fenders.
Prevention Tip: Check tire pressure before every trip and keep an eye on tire age. Don’t wait for visible wear; replace tires as needed.
If a tire blows: Grip the wheel, don’t slam the brakes, and let the rig slow gradually before pulling off. Trailer tires are often a different size than truck tires, so note your trailer’s tire size when you call for help.
2. Hitch Problems
The hitch system for a fifth wheel is complex and unique. If the kingpin isn’t locked correctly or the jaws fail to engage, your trailer could disconnect – an extremely rare but serious risk. Even minor hitch alignment issues can leave you stuck.
Prevention Tip: Visually confirm the jaws are closed and the safety pin is in place every time you hitch. See our step-by-step hitching checklist above.
3. Brake or Electrical Failures
Problems with the trailer’s brakes or lights can make towing unsafe and, in some states, illegal. Corrosion, poor connections, or blown fuses are often the culprits.
Prevention Tip: Include electrical checks in your routine maintenance and pre-trip checklist. Carry spare fuses and learn the basics of troubleshooting.
4. Weight and Balance Issues
Fifth wheels resist sway better than bumper-pull trailers, but overloading still causes trouble. Too much pin weight can push your truck past its payload rating, and an unbalanced load can overload one side’s tires and axles.
Prevention Tip: Know your trailer’s GVWR and your truck’s payload and GCWR. Weigh your loaded rig at a CAT scale or truck stop, and check pin weight, not tongue weight. Exceeding these ratings can lead to blown tires, strained brakes, or frame damage.
5. Tow Vehicle Breakdown While Hitched
If your truck breaks down, your fifth wheel is stranded with it. The trailer can’t move on its own, and you may be parked on a shoulder with a 35-foot trailer still attached. Depending on the situation, the provider may send a heavy-duty wrecker or separate trucks for the tow vehicle and the trailer.
Prevention Tip: Keep up with truck maintenance before long trips, especially cooling systems, transmission fluid and brakes, which work hardest when towing.
6. Low Clearance and Height Strikes
Many fifth wheels stand 12 to 13 feet tall, taller than many drivers expect. Low bridges, gas station canopies, drive-thrus and tree limbs can damage the roof, AC units or front cap.
Prevention Tip: Measure your rig’s actual height, post it on your dash, and use an RV-specific GPS or app that routes around low clearances.
Choosing the Right Roadside Assistance Plan for Your Fifth Wheel
These larger trailers have unique requirements, and a standard auto plan often won’t cut it. Here’s what to keep in mind when comparing options:
1. Coverage That Fits Your Rig
Always read the fine print. Does the plan explicitly cover fifth wheel towing? Many auto roadside assistance plans exclude trailers that exceed certain size or weight limits.
Look for RV-focused plans that offer:
- Towing for both your tow vehicle and fifth wheel.
- Transparent mileage caps or long-haul towing restrictions.
- Coverage that includes remote areas or cross-country travel.
For side-by-side comparison, you can check out Good Sam’s RV roadside assistance plans to see how different plans stack up.
2. Know Your Specs
You should know your trailer’s weight, length, and configuration in addition to the year, make, and model. Roadside assistance providers need these details to send the right equipment and technician to assist you. If your plan doesn’t account for your trailer’s specs, you might be stuck waiting for a second (and better-equipped) tow truck.
3. Service Provider Network
A roadside assistance plan is only as reliable as its service network. Look for providers that offer 24/7 support and work with RV-trained techs who know how to handle fifth wheels safely and efficiently.
4. Added Perks
Some plans offer extras that are especially useful for fifth wheel travelers, such as:
- Trip interruption coverage if a collision with another vehicle interrupts your journey.
- Mobile mechanic dispatch.
- Emergency fuel or fluid delivery.
The bottom line is the more RV-specific the plan, the more peace of mind you’ll have on the road.
Getting Ready for a Roadside Emergency
While you can’t always predict when things will go wrong, you can plan how prepared you are when they do. Here’s how to set yourself up before hitting the road:
Follow a Pre-Trip Checklist
Make these checks a part of your routine before every drive:
- Check tire pressure and tread on both the truck and trailer.
- Inspect the hitch, safety chains, and breakaway cable.
- Confirm that trailer lights and brakes are working properly.
- Verify you have your roadside assistance contact info and membership ID on hand.
Build a Solid Emergency Kit
Pack essentials to help you stay safe and self-sufficient on the road:
- Reflective triangles or road flares.
- Flashlight with extra batteries.
- Basic tools and duct tape.
- Spare tire and jack.
Know Your Rig
Keep your trailer specs (length, weight, VIN) saved on your phone or printed in your glovebox. You’ll need this information when calling for assistance.
Stay Safe
If you break down, pull off the road as far as safely possible. Turn on your hazard lights, set up safety triangles, and stay clear of traffic while waiting for help.
What Happens During a Roadside Assistance Call?
When something goes wrong on the road, knowing what to expect can ease the stress. Here’s how a fifth wheel roadside assistance call typically unfolds – and how to make the most of it:
- Call for Help: Call your roadside assistance provider using their dedicated app or emergency number. Be ready to share your exact location, the issue, and your RV details. Let them know if your trailer is hitched or unhitched, if you’re in a remote area, or if you need heavy-duty towing. The more accurate you are, the better they can dispatch the right help.
- Understand Wait Times: After the call, you’ll receive an estimated arrival time. Delays can happen, especially in rural areas, remote locations, or national parks where service trucks are limited. If your situation requires a heavy-duty tow truck or an RV-trained technician, it may take longer to coordinate and result in longer wait times. Some providers prioritize RVers or send alerts when help is en route.
- Technician Arrives: Once onsite, the technician will assess the issue and either fix it onsite (for example, change a tire or jump-start your battery) or arrange a tow to the nearest qualified facility. In some cases, you may need a second truck – one for your trailer and one for your tow vehicle.
To ensure a smooth service call, communicate clearly and give as much detail as possible when calling the provider. Stay calm and cooperative while prioritizing your safety. Take photos of any damage or mechanical problem to document the condition of your rig and support any future insurance claims.
Wrapping It Up
Towing a fifth wheel opens up an incredible world of adventure. But it also comes with a higher level of responsibility and risk. Having the right roadside assistance plan can make unexpected breakdowns easier to manage by giving you a dedicated resource for coordinating help.
To ensure you're fully covered, explore Good Sam’s Platinum, Platinum Complete, and Platinum+ Plans that include fifth wheel towing. They're the trusted companions to keep you moving confidently on the road.
Frequently Asked Questions (FAQs)
1. What is fifth wheel towing assistance?
Fifth wheel towing assistance is roadside help built for fifth wheel RVs and the trucks that pull them. It typically includes towing for both the trailer and tow vehicle, flat tire service, battery jump-starts, fuel delivery and lockout service, using equipment sized for large rigs.
2. Do standard auto roadside plans cover fifth wheels?
Usually not. Many auto plans exclude trailers above certain size or weight limits, and some entry-level RV plans exclude fifth wheels too. Good Sam’s Standard RV plan, for example, doesn’t cover fifth wheels or motorized RVs. Platinum, Platinum Complete and Platinum+ do.
3. Can I use roadside assistance if I’m boondocking or off-grid?
Coverage for boondocking or off-grid locations varies by provider. Some plans may offer limited or no service in remote areas, so it’s critical to confirm with your provider beforehand. Providing precise GPS coordinates can help facilitate service if it’s available.
4. How much does RV roadside assistance cost?
Good Sam’s RV plans that cover fifth wheels start at $79.95 per year for Platinum, with Platinum Complete at $119.95 and Platinum+ at $219.95.* Higher tiers add benefits beyond basic roadside service.
*Introductory 12-month rates that include a $10 auto-renewal discount. Sales tax may apply. The regular price applies after the first term.
5. Is fifth wheel towing assistance worth it?
If you travel often with a fifth wheel, it’s absolutely worth it. The right plan means faster, safer help in emergencies, and a lot less stress when the unexpected hits.
