Last Updated: May 27, 2026Towing
What vehicle is best for towing a travel trailer?
A family in a white compact SUV towing their travel trailer through their neighborhood on a camping trip.
GS
Good Sam
“Choosing the best vehicle to tow a travel trailer requires several considerations including: Understanding if you have a lightweight, midweight, or heavyweight trailer. From there you'll need to consider: Towing capacity and weight matching, engine power and torque, transmission and drivetrain, and the payload and tongue weight.”
You've found the perfect travel trailer and you're ready to hit the road. Then reality hits: tongue weights, payload limits, and towing capacities come into play. Choosing the wrong setup could leave you stranded or worse.
But that doesn't mean you need a massive truck for every trailer. The right towing vehicle depends on your specific trailer weight, intended use, and driving needs.
This guide breaks down vehicle recommendations by trailer weight, explains key towing factors, and helps you choose the right setup for safe, confident towing adventures.
Key Factors That Determine the Right Towing Vehicle
Understanding what makes a vehicle suitable for towing helps you make informed decisions and avoid costly mistakes. Several critical factors work together to determine towing capability and safety.
  • Towing Capacity and Trailer Weight Matching: Your vehicle's maximum towing capacity must exceed your trailer's gross vehicle weight rating (GVWR) – not just its dry weight. Always maintain a 10-20% safety margin.
  • Engine Power and Torque: Torque matters more than horsepower for towing because it provides the pulling power needed to accelerate with heavy loads.
  • Transmission and Drivetrain: Modern transmissions often include towing modes that adjust shift patterns for better performance under load. Rear-wheel drive typically handles towing better than front-wheel drive.
  • Payload and Tongue Weight: Your vehicle's payload capacity must accommodate passengers, cargo, and tongue weight (typically 10% of trailer weight). Exceeding payload limits affects handling and safety.
Lightweight Trailers (Under 3,500 lbs)
Lightweight trailers include pop-up campers, teardrop trailers, and compact travel trailers. These work well with properly equipped SUVs and crossovers that many families already own.
Best Vehicle Options:
  • Honda Pilot: Offers a 3,500-pound towing capacity with a reliable V6 engine and standard all-wheel drive for enhanced stability.
  • Chevrolet Traverse: Provides a 5,000-pound towing capacity with three-row seating, making it ideal for families seeking versatility.
  • Toyota Highlander: Features a 5,000-pound towing capacity with proven reliability and excellent resale value.
  • Subaru Outback: Delivers a 2,700-pound towing capacity with standard all-wheel drive, perfect for smaller trailers and outdoor enthusiasts.
These vehicles serve as comfortable daily drivers while providing adequate towing capability for weekend adventures. The key advantage is fuel efficiency and maneuverability without sacrificing daily drivability.
Midweight Trailers (3,500-7,500 lbs)
This category covers most 20 to 26-foot travel trailers and represents the sweet spot for many families. These trailers require more substantial towing vehicles but still allow for reasonable fuel economy and daily usability.
  • Ford F-150: America's best-selling truck capable of towing up to 14,000 pounds with proper configuration, providing excellent versatility for various trailer sizes.
  • RAM 1500: Equipped to handle up to 12,750-pound loads with available air suspension for improved ride quality and load leveling capabilities.
  • Toyota Tundra: Offers robust 12,000-pound towing capacity with proven reliability, strong resale value, and comfortable crew cab configurations.
  • Chevrolet Silverado 1500: Features up to 13,300-pound towing capacity with advanced trailering technology and multiple engine options.
Half-ton trucks in this category offer a balance of capability, comfort, and efficiency for most travel trailer applications. Factory towing packages typically include upgraded cooling systems, trailer brake controllers, and enhanced suspension components.
The advantage of these vehicles is their versatility; they handle mid-size trailers confidently while remaining practical for daily use, school runs, and weekend errands.
Heavyweight Trailers (7,500+ lbs)
Large travel trailers, toy haulers, and fifth-wheels require heavy-duty vehicles designed specifically for serious towing. These setups prioritize capability over fuel economy and daily drivability.
  • Ford F-250 Super Duty: Capable of towing up to 20,000 pounds with an available Power Stroke diesel engine providing exceptional torque for challenging terrain and heavy loads.
  • RAM 2500: Equipped to handle up to 19,780 pounds with an optional Cummins diesel engine and advanced trailer management systems for superior performance.
  • Chevrolet Silverado 2500HD: Offers up to 18,500-pound towing capacity with Duramax diesel option and innovative trailering technology, including integrated brake controllers.
  • Ford F-350 Super Duty: Features even higher payload capacity than F-250 while maintaining similar towing capability, ideal for those carrying additional gear while towing.
Heavy-duty trucks excel in challenging conditions like mountain passes, long grades, and extreme weather. Diesel engines provide superior torque and better fuel economy when towing heavy loads, though they require higher upfront costs and more expensive maintenance.
These vehicles are purpose-built for serious towing but come with trade-offs, including higher purchase prices, reduced fuel economy when not towing, and less maneuverable daily driving characteristics.
Best Vehicle by Towing Use-Case
Different towing scenarios require specific vehicle characteristics. Matching your primary use case helps narrow down the right option for your needs.
  • Mountain Towing: Diesel engines excel due to superior torque delivery and engine braking. The Ford F-250 with Power Stroke diesel or RAM 2500 with Cummins diesel provide confident performance on steep grades.
  • Long-Distance Comfort: The Toyota Tundra and Ford F-150 with crew cab configurations offer excellent ride quality and advanced driver assistance features that reduce fatigue during extended travel.
  • Daily Driver Plus Towing: The Honda Pilot and Chevrolet Traverse provide 3,500-5,000 pound towing capacity while offering car-like handling and good fuel economy for everyday family use.
  • Budget-Friendly Option: Used Chevrolet Tahoe and Ford Expedition models offer substantial towing capacity at lower price points with proven reliability.
  • Family-Friendly Choice: The Chevrolet Tahoe and Ford Expedition Max provide excellent towing capacity, three-row seating, and generous cargo space for family gear.
Common Mistakes To Avoid When Choosing a Tow Vehicle
Even experienced RVers sometimes overlook critical factors that can lead to unsafe towing situations. Avoiding these mistakes helps ensure safe, enjoyable travels.
  • Ignoring Loaded Trailer Weight: Many focus only on dry weight specifications, forgetting that loaded trailers weigh significantly more with water, propane, food, and gear. Always plan for full load conditions.
  • Assuming All Trim Levels Have Equal Capability: Base model vehicles often have lower towing capacities than properly equipped versions. Factory towing packages and specific configurations significantly impact capability.
  • Forgetting Tongue Weight in Payload Calculations: Tongue weight typically represents 10% of trailer weight and must fit within your vehicle's payload capacity along with passengers and cargo.
When towing issues arise far from home, services like Good Sam Roadside Assistance provide specialized support with unlimited towing to nearest qualified service center and comprehensive coverage designed specifically for RV travelers.
Towing Technology and Add-Ons to Consider
Modern towing technology significantly improves safety and confidence when pulling travel trailers. Understanding available options helps you choose the right setup.
  • Factory Towing Packages: Include upgraded cooling systems, integrated trailer brake controllers, heavy-duty alternators, and calibrated suspension components that work together more effectively than aftermarket additions.
  • Sway Control and Weight Distribution: Weight-distributing hitches help level your vehicle and improve steering response, while sway control systems reduce dangerous trailer movement from crosswinds or passing vehicles.
  • Advanced Safety Features: Backup camera systems, blind spot monitoring for towing, and trailer tire pressure monitoring provide additional safety layers that help prevent accidents and breakdowns.
Tow Smart with the Right Vehicle
Selecting the right vehicle starts with understanding trailer weight, use cases, and essential towing features. Whether you're pulling a compact teardrop or a large fifth-wheel, the right match ensures years of smooth adventures.
If things don't go as planned, Good Sam Roadside Assistance is there with unlimited towing to the nearest qualified service center, trip interruption support, and 24/7 help built for RVers. Compare Good Sam plans today to stay road-ready.
Frequently Asked Questions
1. Can I tow a travel trailer with an SUV?
A: Yes, many SUVs can safely tow travel trailers when properly matched to weight limits. Three-row SUVs handle mid-size trailers well, while compact SUVs work for lightweight options.
2. How do I calculate how much my vehicle can safely tow?
A: Check your vehicle's towing capacity in the owner's manual, then ensure your loaded trailer weight stays 10-20% below maximum capacity for safety.
3. What's the safest speed for towing a trailer?
A: Most manufacturers recommend maximum speeds of 65 mph when towing, with lower speeds in challenging conditions for improved stability and safety.
