Last Updated: October 28, 2026Maintenance
Winter car maintenance – how to prepare your vehicle for cold weather
Older man in a red jacket brushing fresh snow off a car window with a snow brush on a snowy winter day.
GS
Good Sam
“Winter car maintenance helps you prepare for the unexpected. Essential winter car maintenance includes inspecting and replacing tires, checking your battery, fluid and antifreeze levels, oil and filter changes, and having a stocked a emergency kit.”
As temperatures drop, most drivers in colder parts of the U.S. start layering up, prepping their homes, and tossing a snow brush in the trunk. What many overlook, often until it’s too late, is that winter hits vehicles just as hard. Without the right winter car maintenance, even a reliable car can let you down when you need it most.
Cold weather puts your car under a lot of stress. Batteries lose cranking power, tire pressure drops, oil thickens, wiper blades stiffen, and road salt eats away at the undercarriage. Ignore those warning signs and you could be facing more than a car that won’t start. You could end up stranded miles from home, paying for expensive repairs, or driving in unsafe conditions.
The good news is that many winter breakdowns are preventable, and the best time to prepare is in the fall, before the first hard freeze. Whether you commute daily, head to the mountains for a ski weekend, or just don’t want to be “that person” with the hood up in a snowstorm, this guide covers the key systems to check, what to keep in your car, what to do if you’re stranded, and the winter car myths you can stop believing.
What Car Maintenance Do You Need To Do for Winter?
Winter doesn’t wait. A sudden temperature drop or first freeze can arrive overnight, catching unprepared drivers off guard. That’s why it’s smart to knock out key maintenance tasks early in the season before the cold sets in for good. The following areas deserve your attention not just because they’re common failure points but because they’re all connected to safe, smooth winter driving.
Inspect and Replace Tires
Your tires are your only point of contact with the road. In winter, that contact becomes everything.
  • Winter tires vs. all-seasons – All-season tires may work in light snow, but winter tires are designed for better grip, flexibility, and traction in icy or slushy conditions. The rubber compound remains pliable in freezing temps and that is something standard tires just can’t do.
  • Check your tread – You need at least 6/32" tread depth for decent winter traction. A penny test isn’t enough; use a proper depth gauge or ask your tire shop.
  • Tire pressure drops in cold – Expect to lose 1-2 PSI for every 10°F drop in temperature. Driving on underinflated tires can reduce traction and increase wear. Check weekly.
Battery Maintenance and Checks
Nothing kills a winter morning like a dead battery. Unfortunately, batteries are more vulnerable in cold because chemical reactions slow down in freezing temperatures.
  • Test it before it fails – Most auto shops will test your battery for free. If it’s older than three years or slow to crank, it’s better to replace it now than in a snowstorm.
  • Clean the terminals – Corrosion buildup can reduce conductivity. Use a wire brush and battery-safe cleaner to keep the posts clean.
  • Keep it charged – If your vehicle sits for days at a time, consider a trickle charger or battery maintainer to prevent deep discharge without overcharging.
Fluids and Antifreeze
Cold thickens your oil and it affects nearly every other fluid in your vehicle.
  • Coolant/antifreeze – Your coolant should be a 50/50 mix of antifreeze and water. Too much water can freeze and crack the radiator, and too much antifreeze can overheat the system. Check with a hydrometer or have your shop confirm the mix.
  • Brake fluid and power steering – These should be at proper levels and free of contamination. Old or contaminated fluids can lead to a sluggish response in cold weather.
Oil and Filter Changes
Oil is your engine’s lifeblood, but it thickens in cold weather, making it harder to circulate on startup.
  • Use winter-grade oil – If you live in areas where temps fall below freezing, switching to a thinner oil (like 5W-30 or 0W-20) can improve cold starts. Check your owner’s manual for recommendations.
  • Don’t stretch the interval – Cold-weather driving puts more stress on your engine. Sticking to a regular oil change schedule helps reduce wear and tear.
Windshield Wiper and Washer Fluid
Visibility is non-negotiable in winter. Between snow, road grime, and early sunsets, your wipers work overtime.
  • Replace wiper blades – If they streak, chatter, or leave gaps, it’s time for a new set. Consider winter-specific blades with rubber shielding to prevent ice buildup.
  • Top up washer fluid – Keep a spare bottle in the trunk, and make sure it’s the freeze-resistant kind. A dry reservoir is useless when you need it most.
Winter Emergency Preparedness
Even with the best maintenance, winter driving can surprise you. Black ice, blizzards, or mechanical failures happen. What matters is how prepared you are when they do.
What Should Be In A Winter Car Emergency Kit?
Think of it as your vehicle’s version of a survival bag. Keep these basics in your trunk:
  • Jumper cables or portable jump starter
  • Ice scraper and snow brush
  • Flashlight with extra batteries
  • Emergency blanket or sleeping bag
  • Gloves and hand warmers
  • First aid kit
  • Shovel and sand/kitty litter (for traction)
  • Phone charger (preferably a solar or power bank)
  • Extra windshield washer fluid
  • Reflective warning triangles or road flares
This kit isn’t just for you. It could help a stranger too. Don’t skip it.
How To Prepare for Winter Driving Emergencies
Winter breakdowns can quickly become dangerous if you’re stranded in sub-zero temperatures or remote locations. Being ready isn’t just about having the right gear in your trunk; it’s about knowing how to respond calmly and safely when things go wrong.
  • If you get stuck – Stay inside your vehicle unless it’s absolutely unsafe (e.g., fire risk or if the car is off the road). Run the engine every 10-15 minutes for warmth, but always crack a window to prevent carbon monoxide buildup, and check that the exhaust pipe is clear of snow or ice to avoid deadly fumes backing into the cabin.
  • Let someone know before you leave – Always inform a friend or family member of your planned route, expected arrival time, and when they should expect to hear from you. This simple step could drastically reduce the time you’re stranded if something goes wrong.
  • Keep fuel topped off – Never let your gas tank fall below half during cold weather. A fuller tank reduces the risk of fuel line freeze-ups and prevents excess moisture from condensing inside the tank, which can dilute fuel and damage the engine.
  • Know how to signal for help – If you’re stuck and out of cell service, tie a bright-colored cloth or reflective vest to your antenna or window, and turn on your hazard lights if your battery allows. This increases visibility for passing motorists or search crews.
  • Conserve your battery – In a no-start situation, avoid using power-hungry accessories like heated seats or cabin lights unless absolutely necessary. Preserve power for emergency calls or hazard lights.
  • Don’t leave the car to seek help unless you’re 100% sure where you’re going – Wandering from the vehicle in whiteout conditions can be disorienting and life-threatening. Shelter inside your car is usually your safest bet until help arrives.
  • Know your emergency kit – Have it within reach and not buried in the trunk under gear. Ensure it includes a flashlight, thermal blankets, hand warmers, bottled water, snacks, a shovel, traction aids (like sand or kitty litter), and a backup phone power bank.
  • Check weather alerts before every trip – Even short drives can turn risky in rapidly changing winter conditions. Use reliable sources like NOAA or your state’s DOT travel alerts to avoid surprises.
For added peace and precaution, explore Good Sam Roadside Assistance plans for access to covered roadside services when unexpected winter breakdowns occur.
Winter Car Maintenance Myths (Debunked)
Not everything passed down at the gas pump is true. Let’s clear up a few common myths that could do more harm than good.
  1. “You need to warm up your car for 10-15 minutes” - A minute or two is plenty. Today’s engines are built to warm up as you drive. Idling wastes fuel and contributes to buildup inside the engine.
  2. “All-season tires are good enough for snow” - Not always. Winter tires are specifically designed for cold and traction. If you live where snowfall sticks, they’re a worthwhile upgrade.
  3. “Tire pressure stays consistent” - Cold air causes contraction. Check your pressure weekly in winter.
  4. “Your battery is fine, as it worked last year” - Cold magnifies weak batteries. Always test it at the start of the season.
  5. “Windshield washer fluid is all the same” - Not true. Regular fluid can freeze on contact in low temps, reducing visibility when you need it most. Use a winter-grade washer fluid rated for sub-zero conditions.
  6. “Four-wheel drive means you don’t need winter tires” - While 4WD helps with traction, it doesn’t improve braking or turning on ice. Winter tires are still essential for overall safety.
  7. “You can use water instead of coolant in winter” - A dangerous myth. Water can freeze in the engine and crack vital components. Use the proper antifreeze mix - typically 50/50 coolant and distilled water.
  8. “If it’s sunny, the roads are safe” - Black ice can form even on clear days, especially on bridges and shaded roads. Never let the sunshine fool you into overconfidence.
Seasonal Car Maintenance Schedule
Want to keep winter maintenance simple? Here’s a quick-reference checklist:
  • Check tire pressure: Weekly
  • Test battery: Start of the season
  • Inspect wiper blades: Monthly
  • Top off washer fluid: Monthly
  • Confirm antifreeze mix: Start of the season
  • Check oil level/condition: Monthly or as needed
  • Review emergency kit: Start of the season + mid-winter
Print this and keep it in your glove box, or set calendar reminders so you’re never caught off guard. Even with perfect maintenance, roadside events still happen - Good Sam can help you get back on the road quickly with a plan that meets your needs.
Don’t Let Winter Catch You Off Guard
Winter car maintenance is about protecting your vehicle, your budget, and, most importantly, your safety. The earlier you prepare, the better your chances of making it through the season without surprise repairs or emergency calls from the roadside.
If you’re not comfortable handling some of these tasks yourself, consider scheduling a professional inspection. Compare Good Sam’s auto plans to find coverage that keeps you moving through the worst of winter.
Stay warm knowing that Good Sam offers 24/7 dispatch and coverage for cold-weather breakdowns, no matter where the road takes you.
Frequently Asked Questions (FAQs)
1. What car maintenance should I do before winter?
Before temperatures drop, test your battery, check tire tread and pressure (or switch to winter tires), confirm your antifreeze mix, switch to winter washer fluid, replace worn wiper blades, and get an oil change if you’re due. Then stock an emergency kit for your trunk.
2. When should I switch to winter tires?
Switch when temperatures stay at or below about 45°F (7°C). Many drivers follow the 7-for-7 rule: once it’s 7°C or colder for seven days in a row, put on your winter tires. Use the same rule in reverse to switch back in spring.
3. What temperature is too cold for a car to start?
There’s no single cutoff, but starting gets harder as the temperature drops. Cold slows the chemical reaction inside your battery, so it delivers less power just when thickened oil makes the engine harder to turn over. Below freezing, and especially near 0°F, a weak or older battery is much more likely to fail. A healthy, fully charged battery gives you the best chance on sub-zero mornings.
4. What should I do if my car won’t start in the cold?
Turn off lights and accessories, then try again after a short wait. A clicking sound or slow crank usually points to a weak battery, and a jump start may get you going. If it still won’t start, call roadside assistance. All Good Sam auto plans include 24/7 jump starts and towing to the nearest service center.
5. How often should I change my antifreeze?
Conventional coolant typically needs changing every 2–3 years or 30,000 miles, while long-life coolants often last 5 years or 100,000+ miles. Check your owner’s manual for your vehicle’s schedule, and don’t mix coolant types unless the label says they’re compatible.
6. How do I protect my car from road salt?
Road salt speeds up rust, especially on the parts of your car you can’t see. Wash your car regularly through the winter, and after major storms, focusing on the undercarriage and wheel wells. Touch up any paint chips that expose bare metal, and give the whole car, underneath included, a thorough wash in spring to clear out leftover salt.
