Last Updated: August 17, 2026Service
Why every new driver needs roadside assistance
New driver learning to use jumper cables while an adult connects a dead battery under the hood.
GS
Good Sam
“Handing over the keys is a milestone, but it doesn't have to mean handing over peace of mind. Here's why roadside assistance gives new drivers and their families a critical safety net.”
If you’re wondering why new drivers need roadside assistance, the answer is simple: inexperience increases the risk of breakdowns, and emergencies can happen at any time. Roadside assistance for new drivers provides on-demand help during flat tires, dead batteries, lockouts, and towing needs. For parents of teen drivers, it’s more than convenience. It’s a safety net that protects both your child and your wallet while building confidence behind the wheel.
Why New Drivers Benefit from Roadside Assistance
  • Higher Likelihood of Common Roadside Emergencies: Inexperience often leads to simple mistakes like leaving lights on or misjudging fuel levels.
  • Limited Experience Handling Breakdown Situations: New drivers may not know how to safely change a tire or jump-start a car.
  • Towing and Emergency Services Can Be Expensive without Coverage: A single tow can easily cost more than an annual membership.
  • 24/7 Support Reduces Panic and Unsafe Decisions: Having a professional to call helps teens avoid making risky choices in stressful situations.
  • Provides Reassurance and Peace of Mind for Families: Parents can feel confident their child won’t be stranded or dependent on the kindness of strangers for help.
What Is Roadside Assistance?
Roadside assistance is a 24/7 emergency support service designed to help drivers get back on the road after a mechanical failure or a minor mishap. For new drivers, it also acts as an on-demand backup that helps them get moving again quickly and safely. Understanding how roadside assistance works helps families see it as practical protection rather than an optional extra.
Most roadside assistance plans cover:
  • Towing Services: Transporting the vehicle to the nearest qualified repair facility if it cannot be driven.
  • Flat Tire Assistance: Replacing a flat tire with the vehicle’s spare.
  • Battery Jump-Starts: Reviving a dead battery so the driver can continue their trip.
  • Vehicle Lockout Service: Helping drivers regain entry to their car if keys are lost or locked inside.
  • Emergency Fuel Delivery: Bringing fuel to a driver who has run out.
4 Key Reasons Every New Driver Needs Roadside Assistance
New drivers face unique risks on the road, especially during their first years behind the wheel. Understanding why new drivers need roadside assistance helps families prepare for common challenges and avoid unnecessary stress when the unexpected happens.
1. Inexperience Increases the Risk of Common Roadside Problems
Even the most cautious new driver is navigating a steep learning curve. The mechanical awareness experienced drivers take for granted is still developing. This is not a flaw. It’s simply a part of the learning process.
Common mistakes new drivers make that lead to roadside emergencies include:
  • Leaving headlights or interior lights on, draining the battery.
  • Hitting curbs or deep potholes that can damage tires or cause blowouts.
  • Misjudging fuel range and running out of gas.
  • Ignoring or misunderstanding dashboard warning lights until the vehicle stops running.
Roadside assistance for new drivers helps manage these learning-phase mistakes safely without the situation escalating into a crisis.
2. Emergency Situations Can Be Overwhelming
Breakdowns often happen in stressful environments:
  • Nighttime, when visibility is poor and help seems far away.
  • Busy highways with fast-moving traffic.
  • Severe weather conditions, such as rain, snow, or extreme heat.
  • Unfamiliar areas where safe waiting spots are not obvious.
For an inexperienced driver, these conditions can amplify fear quickly.
Access to 24/7 professional help significantly reduces panic. When teens know they can call for assistance, they’re more likely to make safer decisions, like staying inside the vehicle with hazard lights on rather than walking along the highway.
3. Towing and Emergency Services Can Be Expensive
Without roadside assistance, emergency services can be costly:
  • Towing: $75–$200+ base fee, plus per-mile charges.
  • Jump-Start Service: $50–$100.
  • Lockout Service: $50–$100.
  • Fuel Delivery: Service fee plus fuel cost.
Cost can vary by location and time of service requested. One unexpected breakdown can easily exceed the cost of an annual roadside assistance plan.
With roadside assistance coverage:
  • Towing is included within plan limits.
  • Jump-start services are typically included.
  • Lockout service is covered.
  • Emergency fuel delivery is included (fuel cost may apply).
This financial predictability matters for families managing tight budgets. Planning ahead helps prevent surprise expenses.
4. It Reduces Stress for Both Drivers and Parents
Unexpected vehicle problems can be stressful for a new driver, especially when they are alone. Roadside assistance provides immediate guidance and professional help, so the driver does not have to guess what to do.
For the driver, this means:
  • Staying inside the vehicle instead of attempting risky roadside repairs.
  • Turning on hazard lights and waiting in a safer position.
  • Getting clear instructions during a stressful situation.
For parents, it provides reassurance through:
  • 24/7 access to trained professionals.
  • Help locating and assisting the vehicle.
  • Reduced reliance on strangers for assistance.
  • Coordinated support when they cannot reach the driver quickly.
During the early years of independent driving, this shared support helps both drivers and families handle emergencies more calmly and safely.
Common Roadside Emergencies New Drivers Face
  • Flat Tires: Often caused by hitting curbs or road hazards that an experienced driver might avoid.
  • Dead Batteries: Frequently the result of leaving electronics on or doors ajar.
  • Vehicle Lockouts: A common mistake when juggling keys, phones, and backpacks.
  • Running Out of Fuel: Due to a lack of familiarity with the vehicle’s fuel range and consumption.
  • Minor Mechanical Failures: Newer drivers may not notice the early warning signs of issues like a failing alternator or overheating engine.
What Should a New Driver Do During a Breakdown?
Safety should always come first. If your teen experiences a breakdown, they should follow these steps:
  1. Pull over safely. Move as far away from traffic as possible. If the vehicle is still drivable, exit at the next ramp or pull into a parking lot.
  2. Turn on hazard lights immediately. This alerts other drivers that you are stopped.
  3. Stay inside the vehicle if you are on a busy road, highway, or in an unfamiliar area. A locked car with hazard lights is safer than waiting outside.
  4. Call roadside assistance. Provide your location, vehicle description, and the issue you are experiencing.
  5. Avoid accepting help from strangers. Well-intentioned individuals may offer assistance, but professional help is the safest option.
Do not attempt roadside repairs if:
  • Traffic is heavy and moving at high speed.
  • Visibility is poor due to darkness, fog, or weather.
  • You lack basic safety equipment (reflective triangles, flares, spare tire, jack).
  • The vehicle is not on level, stable ground.
  • You are uncertain what the problem is.
Auto roadside assistance is designed for situations like these.
What Actually Happens After You Call Roadside Assistance
After contacting roadside assistance, the service follows a predictable process:
  1. The dispatcher confirms your location, vehicle details, and the problem.
  2. A nearby technician equipped for the issue is dispatched.
  3. You receive an estimated arrival time.
  4. The technician arrives and verifies the request.
  5. The vehicle is repaired or towed to the nearest qualified repair facility if necessary.
Knowing these steps helps new drivers stay calm because they understand what will happen next.
How Long Does Roadside Assistance Usually Take?
Response times depend on location and conditions:
  • Urban areas: Typically 30–60 minutes.
  • Suburban areas: Usually 45–90 minutes.
  • Rural highways: May take longer depending on distance.
Delays are sometimes unavoidable due to weather, traffic or road conditions, availability, or unusual service demands. Additionally, longer distance tows, after hours service requests, and service requests in certain areas may be subject to longer delays.
When Is Roadside Assistance Especially Important for New Drivers?
While all new drivers benefit from coverage, certain situations make it particularly valuable:
  • The driver frequently travels alone without an experienced passenger.
  • Highway commuting is part of their daily routine.
  • The vehicle is older or high-mileage, increasing breakdown risk.
  • Parents want consistent emergency backup without having to drop everything to respond themselves.
  • The driver is still building confidence, and anxiety about breakdowns is limiting their practice.
In these cases, coverage isn’t just helpful. It becomes an essential layer of protection.
What Happens If a New Driver Doesn’t Have Roadside Assistance?
Without coverage, drivers may face:
  • Unexpected out-of-pocket towing expenses.
  • Delays while searching for local towing companies.
  • Increased stress during emergencies.
  • Greater safety risks while waiting for help.
For example, driving with a weak battery may lead to sudden battery failure while driving. If the car stalls in traffic, the situation can quickly become dangerous. Planning ahead helps prevent such unnecessary risks.
Is Roadside Assistance Worth It for a New Driver?
In most cases, yes. A roadside assistance membership is worth it for most new drivers.
Compare the cost of one tow, often $100 or more, to the annual cost of a roadside assistance plan. One breakdown can justify a full year of coverage.
Beyond cost, the safety benefits are clear:
  • Faster professional response.
  • Less panic during emergencies.
  • Reduced exposure to roadside risks.
For families wondering why new drivers need roadside assistance, the combination of financial protection and safety reassurance makes it a smart preventative step.
How Much Does Roadside Assistance Cost for New Drivers?
Roadside assistance plans typically range from about $50 to $100 per year, depending on:
  • Coverage level
  • Towing mileage limits
  • Additional benefits
  • Multi-vehicle or family options
Pricing varies by provider and plan tier. When evaluating plans, think of it not as an expense but as a preventative safety investment, similar to the cost of a fire extinguisher or first aid kit.
Roadside Assistance vs. Insurance Towing Coverage
Many parents assume their auto insurance policy already provides roadside support. While some insurers offer basic roadside assistance as an add-on, there are key differences:
  • Towing Limits: Insurance-based towing often only covers a few miles, which may not be enough to get the car to a preferred shop. Dedicated plans often offer longer towing distances.
  • Claims Records: Some insurance companies may track roadside calls internally, which could potentially impact your premiums.
  • Specialization: Dedicated roadside providers are built for speed and 24/7 reliability, whereas insurance companies often outsource these tasks to third-party dispatchers.
Dedicated roadside assistance plans are designed specifically for emergency vehicle support. They often provide clearer towing mileage limits and streamlined service coordination.
What To Look For in a Roadside Assistance Plan for New Drivers
When choosing a plan, look for features that prioritize safety, convenience, and reliability:
  • 24/7 Nationwide Service: Ensure the coverage follows the driver wherever they go in the U.S.
  • Clear Towing Mileage Limits: Look for plans that offer towing to the nearest qualified service center or a specific mile radius.
  • Comprehensive Services: Ensure lockouts, fuel delivery, and battery jump starts are included.
  • Ease of Use: A mobile app or a simple 1-800 number is essential for a stressed teen.
  • Multi-Vehicle or Family Options: Some plans allow coverage for multiple drivers or cars, providing a cost-effective way to protect the whole family.
Comparing the available roadside assistance plans helps ensure the coverage matches your family’s needs.
Conclusion
Handing over the keys is one of the biggest milestones in parenting a teenager. You have prepared them for the rules of the road. Roadside assistance prepares them for the unexpected.
It’s affordable protection against expensive surprises. It’s a panic-reducing resource during stressful moments. It’s the reassurance that when you call for help, a trained professional will answer.
Roadside assistance won’t prevent every mistake. Learning to drive always involves trial and error. But it helps ensure those errors remain learning experiences rather than safety emergencies.
Frequently Asked Questions (FAQs)
Is roadside assistance required for new drivers?
No, it is not legally required. However, it is strongly recommended as a safety and financial protection measure.
Can a new driver use their parents’ roadside assistance plan?
It depends on the plan. Some plans cover a specific vehicle, meaning anyone driving it is protected. Others cover the member, so the new driver would need their own membership or to be added to a household plan. Family roadside assistance options often include multi-vehicle or household coverage.
Does using roadside assistance increase insurance rates?
Not when using a dedicated roadside assistance provider. Insurance-based programs may count service calls as claims, which could potentially impact rates in some cases.
How far will roadside assistance tow a vehicle?
Towing distance varies by plan. Basic plans may include 3-5 miles, while premium plans offer 10, 25, or even 100 miles. Good Sam Roadside Assistance offers unlimited towing to the nearest qualified repair facility in lieu of a mileage limit. Always check the towing mileage limits before selecting a plan.
Can roadside assistance cover multiple drivers?
Yes. Many providers offer household plans that cover all licensed drivers in a home, or multi-vehicle plans for multiple family cars.
Can roadside assistance be purchased as a gift for a new driver?
Absolutely. Many services offer gift memberships. It is a practical, thoughtful gift that shows support and confidence in the new driver.
What happens if I don’t have roadside assistance and my car stalls unexpectedly?
You will need to arrange and pay for towing or repair services yourself. This often means finding a provider, arranging payment, and waiting longer for help while managing the risk of being stranded.
