Last Updated: September 15, 2026Travel Tips
What to do if your car breaks down
Raised hood and exposed engine of a broken-down vehicle stopped by a rural field
GS
Good Sam
“The first few minutes after a breakdown matter most. Hazard lights, the right pull-over spot, and a quick call for help can keep a stressful situation from becoming a dangerous one.”
A car breakdown on a busy highway or late at night can feel overwhelming. Traffic moves fast, visibility drops, and it’s not always clear what to do next. Knowing what to do if your car breaks down helps you stay calm, reduce risk, and make safer decisions for yourself and your passengers.
With clear, safety-first steps, you can manage an unexpected breakdown without panic, protect everyone involved, and avoid turning a manageable situation into a dangerous one. This step-by-step guide walks you through what to do if your car breaks down, including immediate safety steps, who to call for help, and how to stay safe until assistance arrives.
Quick Safety Checklist: What To Do Right Away
  • Turn on your hazard lights immediately.
  • Move to the right shoulder or a safe location.
  • Stay inside with your seatbelt fastened.
  • Call roadside assistance or emergency services.
  • Use visible distress signals.
7 Immediate Safety Steps To Take After Your Car Breaks Down
When your vehicle breaks down, these seven steps form your safety protocol. Follow them in order to protect yourself, your passengers, and other drivers while you wait for help to arrive. Each step builds on the one before it, so move carefully and focus on staying safe.
1. Stay Calm and Assess the Situation
Take a deep breath and assess what’s happening. Understanding whether the issue is mechanical, a flat tire, or a dead battery helps you decide if you can safely move your vehicle or need immediate help.
2. Turn On Your Hazard Lights
Turn on your hazard lights right away. This helps alert other drivers on the road that your vehicle is in distress and helps reduce the risk of rear-end collisions.
3. Carefully Get Your Vehicle to a Safe Location
If the vehicle still runs, use any remaining momentum to guide your car to safety. Look for a wide shoulder, exit ramp, or parking lot, and pull as far right as possible.
If your car dies in an active traffic lane and won’t move, stay inside with your seatbelt fastened and call 911 immediately.
4. Turn Your Wheels Away from Traffic
Once stopped, turn your steering wheel so the front tires point away from the road. This helps prevent your car from rolling back into oncoming traffic if it’s stuck or if the parking brake fails.
5. Engage the Parking Brake
Set the parking brake firmly. Combined with turning your wheels away from traffic, this keeps your vehicle stationary while you wait for help.
6. Decide Whether to Stay Inside or Exit Safely
In most situations, staying inside your vehicle is safer, especially on a busy road or highway. Only exit if there is immediate danger like fire, smoke coming from under the hood, or fuel leakage. If that happens, move far away from your car and call 911.
7. Call for Roadside Assistance or Emergency Help
If you have roadside assistance coverage, like Good Sam Roadside Assistance, you may be able to request help by phone or through your provider’s mobile app. If your vehicle is blocking traffic or poses a safety risk, contact emergency services. Share your exact location, noting exit numbers, mile markers, or nearby landmarks, so help can reach you quickly. you may be able to request help by phone or through your provider’s mobile app. If your vehicle is blocking traffic or poses a safety risk, contact emergency services. Share your exact location, noting exit numbers, mile markers, or nearby landmarks, so help can reach you quickly.
What To Do If Your Car Breaks Down on the Highway
Highway breakdowns carry extra risk due to high-speed traffic and limited reaction time. Knowing what to do if your car breaks down on the highway helps you make quick, safety-first decisions and reduce the risk of a secondary accident.
If you’ve broken down on a highway:
  • Move to the far right shoulder whenever possible.
  • Use any remaining momentum to coast safely out of traffic.
  • Never stop in an active traffic lane unless your vehicle is completely disabled.
  • Exit the vehicle from the passenger side if you must leave it.
  • If you exit the vehicle, stand well away from the roadway, ideally behind a guardrail.
  • Never attempt repairs on a busy highway.
  • Stay inside with your seatbelt fastened while waiting for help.
  • Contact the highway patrol or call 911 if your vehicle is stuck in a traffic lane.
What To Do If Your Car Breaks Down at Night
When your car breaks down at night, reduced visibility becomes your biggest challenge. Darkness makes it harder for other drivers to see you and increases the collision risk. Making your vehicle as visible as possible is essential while you wait for help to arrive.
If your car breaks down at night:
  • Turn on hazard lights immediately.
  • Keep your interior dome light on to improve visibility.
  • Place reflective warning triangles behind your vehicle if it’s safe to do so.
  • Position the first triangle about 10 feet behind your car, the next at 100 feet, and the third 200 feet back.
  • Never use road flares if you smell gas or suspect a fuel leak.
  • Stay inside your vehicle with doors locked, especially in isolated areas.
  • Avoid accepting help from strangers.
  • If someone stops to help, crack your window slightly and ask them to contact the police.
Who To Call for Help When Your Car Breaks Down
Knowing who to call when your car breaks down on the highway or anywhere else depends on where your vehicle is stopped and how serious the situation is.
  • For minor mechanical issues like a flat tire or a dead battery, call your roadside assistance provider first.
  • For engine failure on interstates or high-speed highways, contact roadside assistance and notify the highway patrol if your vehicle creates a traffic hazard.
  • If your car is stuck in an active traffic lane or an unsafe position, contact the state highway patrol immediately.
  • For accidents, injuries, or immediate danger, call 911 right away.
If you don’t have roadside assistance coverage, contact a local towing service directly. Highway towing costs can run several hundred dollars, especially for long-distance or after-hours services.
What Information To Share When You Call for Assistance
Providing accurate information helps emergency services or roadside assistance locate you quickly and send the right support. Be ready to share:
  • Your exact location (mile marker, exit number, or GPS coordinates).
  • Vehicle make, model, color, and license plate.
  • A brief description of the problem.
  • Whether you’re in a safe location or facing immediate danger.
  • Any hazards (heavy traffic, fuel leak, or injuries).
How To Signal for Help When Your Car Is Disabled
A distress signal lets other drivers and emergency responders know that your vehicle is disabled. Using the right signals reduces the risk of accidents and helps roadside assistance find you faster.
Here’s what you can use to signal for help:
  • Hazard Lights: Your most important signal.
  • Reflective Warning Triangles: Place about 100 feet behind your vehicle, if it’s safe.
  • Road Flares: Use only if there is no gasoline smell or fuel leak.
  • Raising the Hood: Universal sign of car trouble.
  • White Cloth Tied to Antenna or Door Handle: A traditional distress indicator.
How To Stay Safe While Waiting for Help
Once help is on the way, your focus should be on staying safe, visible, and alert until assistance arrives. Be sure to:
  • Keep your seatbelt fastened while waiting inside the vehicle.
  • Lock your doors and keep windows mostly up.
  • Stay alert to approaching traffic and watch your mirrors.
  • Conserve your phone battery while you wait.
  • Avoid standing outside unless absolutely necessary.
Is Your Car Broken Down or Temporarily Disabled?
Understanding whether a breakdown is temporary or requires towing helps you decide the safest next step.
Temporary Issues That May Not Require Towing
  • Out of gas.
  • Dead car battery.
  • Overheated engine.
  • Temporary electrical glitch.
Issues That Typically Require Towing and Repairs
  • Blown tire without a spare.
  • Engine failure.
  • Transmission problems.
  • Severe alternator failure.
What To Do If Your Car Is Smoking or on Fire
If you see smoke, flames, or smell burning, act immediately.
  • Turn off the engine right away.
  • Get all passengers out of the vehicle.
  • Move at least 100 feet away.
  • Call 911 immediately.
  • Do not open the hood if flames are visible.
What Not To Do If Your Car Breaks Down
Certain actions can turn a manageable breakdown into a dangerous situation. Avoid these common mistakes:
  • Do not stand in active traffic lanes.
  • Do not attempt major repairs on a busy highway.
  • Do not leave your vehicle unattended for long periods.
  • Do not accept help from unverified strangers at night.
  • Do not turn off hazard lights while stopped on the roadside.
Common Reasons Cars Break Down on the Road
Understanding common breakdown causes can help prevent them and support quicker, safer decision-making during emergencies. Be wary of common issues like:
  • Dead Battery: Typically lasts 3 to 5 years.
  • Engine Overheating: Often caused by coolant leaks or cooling system failure.
  • Flat or Blown Tire: Commonly due to road hazards and worn tread.
  • Alternator Failure: Prevents the battery from recharging.
  • Fuel System Issues: May result from clogged filters or failing fuel pumps.
How To Prepare for a Car Breakdown Before It Happens
The best response to a breakdown starts before you ever face one. These simple preparations can make a critical difference and prepare you to manage an unexpected roadside emergency:
  • Keep an emergency kit with jumper cables, a flashlight, reflective warning triangles, a first aid kit, and basic tools.
  • Maintain your battery with annual testing.
  • Check tire pressure and tread regularly.
  • Keep your gas tank at least one-quarter full.
  • Carry a fully charged phone and a car charger.
  • Consider roadside assistance coverage for reliable, 24/7 support.
Is Roadside Assistance Worth It During an Emergency?
When a breakdown strikes, the financial impact can add up quickly. Understanding typical costs helps you evaluate whether roadside assistance coverage makes sense.
Calling a tow truck can cost anywhere from $40 to $300 on average for tows up to 50 miles. Long-distance (100+ miles)  or highway towing may run several hundred dollars, especially after hours. In some cases, your insurance company may coordinate towing, but response times and coverage can vary.
Beyond cost, dedicated roadside assistance offers faster and more predictable access to help through established networks of pre-screened technicians. Comparing Good Sam’s auto roadside assistance plans can help you choose coverage that fits your driving needs.
Final Thoughts on Staying Safe During a Breakdown
A car breakdown is stressful, but being prepared makes it manageable. Turn on your hazard lights, move to a safe location, stay inside when possible, and call for help promptly. Following these safety-first steps protects you, your passengers, and other drivers on the road.
Keep an emergency kit, maintain your vehicle regularly, and consider roadside assistance for peace of mind. Having access to a trusted roadside assistance network can make breakdowns less stressful and more manageable. Good Sam’s roadside assistance plans provide 24/7 access to professional help and a nationwide network of trusted service providers, so you can drive with confidence knowing support is just a call away.
Frequently Asked Questions (FAQs)
What is the first thing you do if your car breaks down?
Turn on hazard lights immediately to alert other drivers. Then, if possible, safely move your vehicle to the shoulder or another safe location away from traffic. It’s also worth checking your insurance policy to understand what roadside services, if any, are included.
Can you leave your car on the highway if it breaks down?
Avoid leaving your car unattended for extended periods. Laws vary by state, and your vehicle may be subject to enforcement action. Walking along highways is extremely dangerous, so stay with your vehicle and call for help.
What should you not do if your car breaks down?
Never stand in active traffic lanes, attempt to fix the issue on busy highways, or accept help from strangers at night. Keep your hazard lights on and avoid leaving your vehicle unattended for long periods.
Is it safer to stay inside my car during a breakdown?
In most situations, yes. Staying inside with your seatbelt fastened protects you from traffic and weather. Only exit if there is immediate danger, like fire or fuel leakage.
How long can a car remain on the side of the road?
Time limits vary by state. Some states consider a vehicle abandoned after 24 hours, others after 48 hours or longer. Vehicles may be towed sooner if they pose a safety hazard. It’s best to always arrange assistance promptly.
Do police assist with broken-down vehicles?
Yes, police or highway patrol can assist, especially on highways. They help control traffic, provide safety, and connect you with towing services. Call 911 if your breakdown creates a traffic hazard.
