Last Updated: August 11, 2026Service
Roadside assistance for electric vehicles (EVs): what you need to know
White flatbed tow truck with an empty deck waiting curbside, ready for a vehicle recovery
GS
Good Sam
“Switching to an EV doesn't switch off the need for roadside help. Find out what's covered, why flatbed towing is non-negotiable, and how to choose a plan built for electric drivers.”
Roadside assistance for electric vehicles (EVs) provides emergency support such as towing, flat tire help, lockout service, and in some areas, mobile charging. While EVs eliminate fuel-related breakdowns, they introduce unique challenges like battery range limits and specialized towing requirements.
As millions of Americans switch to electric vehicles for lower operating costs and advanced technology, understanding how roadside assistance for electric vehicles works — and what coverage details matter — is essential for staying protected when the unexpected happens.
In this guide, we break down the nuances of electric vehicle roadside coverage, helping you navigate the unique challenges of EV ownership and how to ensure you're never left stranded.
Is Roadside Assistance Different for Electric Vehicles?
Yes. Roadside assistance for electric vehicles differs from gas-powered vehicles because EVs rely on high-voltage battery systems and require specialized towing procedures. While services like lockout assistance and tire changes remain similar, battery-related issues and drivetrain design mean EVs must be handled differently to prevent damage.
High-Voltage Battery Systems
Unlike traditional vehicles, EVs operate on large lithium-ion battery packs. In the event of an accident or a major electrical fault, roadside technicians must be trained to handle these systems safely. A standard jump-start for a 12V battery may restore basic systems, but diagnosing, repairing, or installing the main EV battery requires professional tools and training, and strict safety protocols.
Specialized Towing Considerations
Most manufacturers prohibit "dolly towing" or "two-wheel towing" for EVs. Because electric motors connect directly to the axles, towing with wheels on the ground can generate power through regenerative braking. This can overheat components and cause mechanical damage. Flatbed towing is often the preferred and safest option for EVs.
EV Weight Differences
EVs are often significantly heavier than their gas-powered counterparts due to the weight of the battery packs. Some heavier electric SUVs and trucks exceed 7,000 lb. Roadside assistance providers must use trucks capable of safely handling that weight, which not every standard tow truck can manage.
No Fuel Delivery Needed
Unlike gas vehicles, EVs don't need fuel delivery. Some roadside assistance providers now offer mobile charging, which provides a small power boost to reach the nearest charging station. However, this service is still limited by location, and towing remains the most reliable solution when an EV runs out of charge.
Manufacturer Guidelines
Each automaker provides specific instructions for securing and transporting its EVs. A reliable roadside assistance provider ensures responders follow these guidelines to protect the vehicle and prevent costly damage.
Can Roadside Assistance Recharge an EV on the Spot?
In some cases, yes, but availability is limited. Some providers offer mobile EV charging in select U.S. cities, but it is not guaranteed nationwide. Even when available, this service typically provides enough charge to reach the nearest charging station rather than fully recharge the battery.
The key limitations EV owners must understand include:
  • Limited Availability: This service is typically available in major metropolitan areas. In rural or remote regions, roadside assistance will usually arrange a tow instead.
  • On-Site Charging Not Always Included: On-site charging may be an add-on or reserved for a higher-tier plan. EV owners should review their coverage details carefully.
  • Limited Range: A short charging session usually provides enough power to reach the nearest public charging station, but not to continue a long drive.
  • Time and Variability: Dispatching specialized equipment can take longer, and wait times may vary by location and time of day.
Understanding these limitations helps set realistic expectations when you call for roadside assistance.
What Services Are Included in Roadside Assistance for EVs?
When evaluating roadside assistance services for EVs, it is important to look for coverage that supports both mechanical and electrical needs.
Services typically covered under roadside assistance plans include:
  • EV Towing Service: This is the cornerstone of EV roadside assistance. If your vehicle runs out of charge, coverage should include towing the vehicle to the nearest charging station or qualified repair facility.
  • Flat Tire Assistance: EVs often lack a spare tire to save weight and improve range. Roadside assistance plan may provide on-site tire help or tow the vehicle to a tire shop.
  • EV Lockout Service: Electronic systems and digital keys can fail. Lockout service helps you regain access without damaging seals or sensors.
  • 12V Battery Jump-Start: Even with a large EV battery, a dead 12V battery can mean your car won't start.
  • EV Winching Service: If you slide off a snowy road, specialized winching is required to safely recover your EV without damaging the underbody.
  • Mobile EV Charging Service: When available, this premium feature provides an emergency charge to help reach a nearby charging station.
Each of these services plays a role in helping EV owners handle unexpected situations with confidence.
Can EVs Be Towed Like Gas-Powered Cars?
No. Most EVs cannot be safely towed like traditional gas-powered cars. Using a conventional "two-wheel lift" or dolly tow can cause severe and expensive damage to the electric motors, regenerative braking systems, and drivetrain components. Because of these risks, roadside assistance for electric vehicles relies on different towing methods.
Flatbed Towing Preference
Flatbed towing places the entire vehicle on a flatbed truck with all four wheels off the ground. This prevents drivetrain movement and is considered the safest option, recommended by most EV manufacturers.
Regenerative Braking Risks
Regenerative braking is a miracle for efficiency, but a nightmare for improper towing. When the wheels turn, they generate power that feeds back into the battery system. During a tow, this unregulated energy can damage inverters, blow fuses, or harm other electrical components.
AWD vs. RWD Considerations
Most modern EVs are All-Wheel Drive (AWD) with motors on both axles. This makes traditional tow dollies unsafe. You should always inform your roadside provider that you are driving an EV so they dispatch a flatbed truck.
Manufacturer-Specific Towing Instructions
Some EVs have a dedicated "tow mode" or specific neutral or park settings that must be activated before transport. A knowledgeable roadside assistance provider will follow these protocols to avoid mechanical or electrical damage.
Does Standard Roadside Assistance Cover EVs?
In most cases, yes. Many standard roadside assistance plans cover EVs for basic services like lockouts, flat tires, and towing. However, coverage details matter more for EV owners, especially when it comes to towing distance and battery-related support.
Key points EV owners must review include:
  • Towing Distance Limits: Basic plans often cap towing at 5-10 miles. For EVs, which may need to reach a distant charging station or specialized service center, unlimited towing to the nearest qualified facility is often a major advantage of higher-tier plans.
  • Qualified Repair Networks: Not all repair shops are equipped to service EVs. Ensure the plan provides access to EV-capable facilities, not just general mechanics.
  • Battery-Related Coverage: Confirm that services for the 12V battery are covered, and understand how the plan handles high-voltage battery issues, which are typically covered by the manufacturer's warranty.
  • Manufacturer vs. Membership Plans: Most new EVs include complimentary roadside assistance, but this coverage often expires after 3-5 years. A standalone membership plan like Good Sam Roadside Assistance can provide continuous, long-term coverage beyond the warranty period. can provide continuous, long-term coverage beyond the warranty period.
Are EV Roadside Services Available Nationwide?
Towing services are widely available across the U.S., making them the most dependable solution for EVs. However, more specialized roadside assistance for electric vehicles, specifically mobile charging, is still limited by location.
In major cities, EV owners may have access to mobile charging, faster response times, and a dense network of EV-certified tow operators. However, in rural America, roadside assistance usually relies on towing to the nearest capable facility, which could be many miles away.
Before choosing a roadside assistance plan, EV owners should find out the coverage areas, response expectations, and towing distance limits. This is especially important for drivers who take long road trips or regularly travel through less populated regions.
Is Roadside Assistance Worth It for EV Owners?
For most EV owners, yes. The potential for unexpected breakdowns, limited charging infrastructure in some areas, and the high cost of unplanned towing make roadside assistance a valuable investment for EV owners.
EV owners must consider:
  • Towing Costs: With an average $100 hook-up fee plus $7.00 per mile for a flatbed truck, a single long-distance tow can easily cost over $200 out-of-pocket. A comprehensive roadside assistance plan often costs less annually.
  • Charging Infrastructure Gaps: Even with careful planning, "broken" chargers are a reality. Arriving at a station with 2% battery and no available charger can leave you stranded. Roadside assistance provides a reliable backup.
  • Post-Warranty Coverage: Manufacturer's roadside assistance typically ends when your bumper-to-bumper warranty expires. A standalone plan ensures continued protection as your vehicle ages.
Roadside assistance provides more than cost savings. The security of knowing one call can bring help 24/7, whether it's a flat tire or a depleted battery, helps you get back on the road with less stress and uncertainty. For newer EV owners still learning their vehicle's range, it helps them stay confident, informed and prepared when the unexpected happens on the road.
How To Choose the Right Roadside Assistance Plan for Your EV
Choosing the right roadside assistance for electric vehicles means looking beyond the price and evaluating features that matter most for your EV. You need to focus on how well the plan supports real-world EV situations, especially those involving towing, charging access, and response coverage.
When evaluating an EV roadside assistance plan, use the checklist below:
  • Unlimited Towing: Look for plans that offer long-distance or unlimited towing to the nearest qualified repair facility or charging station. This feature addresses the most common EV roadside scenario.
  • Nationwide Coverage: Ensure the provider has a robust network across all states you regularly drive.
  • 24/7 Dispatch: Breakdowns don't keep business hours.
  • EV-Friendly Towing Support: Confirm the plan recommends or requires flatbed towing for EVs.
  • Mobile App Access: A well-designed app allows you to request help quickly, share your precise location, and access real-time information about service status and arrival times.
  • Coverage for Multiple Vehicles: If your household has more than one car, a plan that covers all is more economical.
Providers like Good Sam offer tiered plans (Platinum Auto, Platinum+ Auto, and Platinum Complete Auto), allowing you to choose the service benefits that match your driving habits and risk tolerance. Reviewing these options carefully helps ensure your final choice fits your driving habits and needs.
So, Do EV Owners Really Need Roadside Assistance?
EVs simplify many aspects of car ownership, but they don't make you immune to the unexpected problems. While EVs eliminate issues common to gas engines, they introduce new variables, such as charging availability, range fluctuations, and specialized assistance requirements.
Cold weather, malfunctioning public charging stations, and long distances between chargers can quickly turn a minor issue into a stressful situation. Relying only on a manufacturer's limited roadside coverage may leave gaps, particularly once warranties expire or when driving in rural areas.
For long-term peace of mind, a dedicated roadside assistance membership is a smart, affordable layer of protection. Before you head out on your next road trip, take a moment to review Good Sam's Auto Roadside Assistance options to ensure that no matter where your electric journey takes you, help is just a phone call away. ensure that no matter where your electric journey takes you, help is just a phone call away.
Frequently Asked Questions (FAQs)
How far will roadside assistance tow an EV?
Towing distance depends on your specific plan. Basic plans may cover only 5–10 miles, while premium roadside assistance plans often provide extended or unlimited towing to the nearest qualified charging station or repair facility.
Can roadside assistance recharge my EV?
Some providers offer mobile EV charging in select U.S. cities, typically providing enough charge to reach a nearby charging station. If mobile charging is unavailable, the vehicle is usually towed instead.
Is EV roadside assistance more expensive?
Generally, no. Many providers include EV coverage under their auto plans at no additional charge. Premium tiers are often recommended for EV owners due to the better towing benefits.
What if my EV runs out of charge?
If your EV runs out of charge, roadside assistance will typically tow it to the nearest charging station or your home. While waiting, turn on hazard lights, conserve battery power by switching off non-essential systems, and move to a safe location if possible.
