Last Updated: May 27, 2026Service
Lost your car keys? 7 immediate steps to take and what to do next
A woman looking for her keys in her purse while standing outside of her white car.
GS
Good Sam
“Losing your car keys can be a cause for panic but it's critical to stay calm, search for a spare key, and try to use a GPS or bluetooth tracker if applicable. Of course, don't forget to check if your car is actually locked. If it is, call Good Sam roadside assistance or a locksmith. ”
Picture this: You’re rushing out of work, juggling a laptop bag, grocery list, a half-read email on your phone, and half-finished coffee, when you reach into your pocket or purse - and stop cold. No keys. You check again and again. They’re gone.
Maybe they slipped between the seats, maybe you dropped them at the gas station, or maybe, worst-case, they’ve vanished entirely. In that split second, your brain kicks into overdrive, thinking - How will I get home? Who do I call? What now?
Losing your car keys is one of those everyday emergencies that catches you completely off-guard. It's inconvenient, stressful, and, in some cases, expensive or unsafe. But as alarming as it feels in the moment, this isn’t a disaster. It’s a solvable problem, and the key (pun intended) is knowing what to do next.
This guide tells you exactly what steps to take. From double-checking the obvious to navigating locksmith options, dealership visits, or even dealing with possible theft, we walk you through what to do if you lose your car keys, one clear, practical step at a time.
Whether you're parked in your driveway, stuck in a shopping center lot, or late for an appointment, these seven steps are your go-to blueprint for turning a key crisis into a manageable hiccup.
Step 1: Stay Calm and Double-Check
Losing your keys can feel stressful, but most of the time they’re just misplaced. Take a moment to pause, breathe, and refocus. Then, work through a few focused steps:
  • Retrace Your Movements: Replay where you’ve been and what you were doing. Think beyond obvious spots, like setting keys down while loading groceries or digging through a gym bag.
  • Check Key Zones: Go through coat pockets, purse compartments, jacket linings, and the area around your car. Keys often slip into unnoticed spaces.
  • Scan Surfaces: Look over tables, counters, car floors, seat crevices, and other places where keys may have dropped or blended in.
A calm, methodical search often works better than frantic searching. Give yourself a few steady minutes before jumping to conclusions.
Step 2: Look for a Spare Key
Before you contact a locksmith or dealership, take a moment to think if you’ve already planned ahead. Many drivers keep a spare key and forget about it until they actually need it.
Here’s where to look:
  • At Home: Check common spots like a key rack, a drawer, or under a potted plant. If you use a magnetic key holder, it might be attached underneath your vehicle.
  • With Someone You Trust: Text or call a partner, roommate, or friend who might have your backup key for emergencies or past errands.
  • If You're Away from Home: Ask if someone can bring the spare to you, or use a ride-share or get help from a friend to pick it up.
A spare key can be the fastest and easiest solution if you know where it is or who has it.
Step 3: Use Bluetooth or GPS Trackers
If you’ve attached a tracker to your keys, now is the perfect time to put it to use. These small devices can save you time and stress by pointing you straight to your keys with just a tap on your phone.
Try the following:
  • Ping the Tracker: Open the app for your AirTag, Tile, or other device to view the last known location.
  • Play a Sound: Many trackers have built-in alarms that can ring loudly enough to be heard through cushions, walls, or even the car trunk.
  • Plan Ahead: If you don’t have a tracker yet, consider getting one. They are an affordable way to prevent this kind of hassle in the future.
A simple tech upgrade today can help you avoid hours of frustration later.
Step 4: Check If Your Car Is Locked or Unlocked
Before you dive into full-on problem-solving mode, stop and check the obvious - is your car actually locked? It might sound silly, but in the middle of a stressful moment, it’s easy to assume the worst. Confirming this one detail will shape your next move and possibly save you time, money, and stress.
  • Unlocked? You’ve Caught a Break
If you can get in, you’re already ahead of the game. Step inside, lock the doors (especially if you're in an unfamiliar area), and take a moment to regroup. You’ll be warmer, safer, and in a better mindset to make your next call. This also gives you access to anything stored inside, such as a spare key, registration, or your phone charger if battery life is low.
  • Locked? Don’t Get Creative
It’s tempting to try cracking the door open with a hanger or even a shoelace if you've seen those YouTube hacks, but resist. These DIY tricks can damage locks, scratch paint, or trigger your car alarm. Worse, they may void your insurance or make it harder to file a claim. Take a minute to assess your surroundings. Are you in a well-lit, safe area? Is your phone charged? These answers will help you decide whether to call a locksmith, roadside assistance or a family member for support.
  • Check All Entry Points
Before calling for help, try all doors and the trunk. Sometimes, one door doesn’t lock properly, or the hatch may have been left slightly ajar. It’s a small win that can make a big difference.
Step 5: Call a Professional Locksmith or Roadside Assistance
If you're locked out and have no way back in, it’s time to turn to professionals. Here’s how to do it efficiently:
  • Licensed Locksmith: Be ready to show your ID and vehicle registration. A locksmith can unlock your car and, if necessary, make a replacement key on the spot. Costs usually range from $50 to $150, depending on the key type.
  • Roadside Assistance Provider: If you're enrolled with Good Sam, AAA, or your insurance provider's roadside service, contact them. They’ll verify your membership and send a trained technician to help. Good Sam Roadside Assistance includes lockout support with all plans, making it easy to get help fast. While Good Sam Roadside Assistance provides lockout help, the cost of key replacement or programming is not covered under the service.
  • What You’ll Need to Share: Give your exact location, vehicle make and model, the type of key (standard, transponder, or fob), and whether you’re locked inside or outside. This helps them bring the right tools and arrive quickly.
  • If Your Phone Is Locked in The Car: Head to the nearest business, gas station, or hotel and ask to use their phone. It’s helpful to keep your roadside provider’s number written down in your wallet or on a key tag. If someone you trust is nearby, they can also call your provider on your behalf. Most services allow this as long as they can verify your membership.
Planning ahead can make a stressful situation much easier to handle when it happens.
Step 6: Contact Your Dealership (Especially for Key Fobs)
When it’s a smart key situation:
  • Gather Key Details - Have your VIN, proof of insurance, and personal ID ready, as dealerships need these to protect against fraud.
  • Dealership Timeline - These replacements often require order and programming time, which can sometimes be days, so ask if they can send an expedited unit or pair you with a trusted locksmith.
  • Cost Heads-Up - Fob replacements routinely range from $200 to $400+, depending on the brand. Meanwhile, expect about $100–$150 for traditional key work.
Step 7: File a Report if Theft Is Suspected
Sometimes, losing your keys isn’t just about forgetfulness and could signal something more serious. If you have even a slight suspicion that your keys were stolen, it’s critical to treat the situation as a security threat, not just an inconvenience.
  • Contact Local Authorities - Contact your local police department and report the situation, even if you’re not 100% sure it’s a theft. Provide essential details like when and where you last saw your keys, any suspicious activity you noticed, and your vehicle’s make, model, and license plate number. In many jurisdictions, the police can mark your vehicle as “flagged” in their system. That way, if someone tries to use the keys to move the car or is found near it, it raises an alert. Even if it’s not considered a criminal offense, having a report on file protects you down the line, especially if your car ends up missing or tampered with.
  • Let Your Car Insurance Provider Know - If your keys were stolen (and not just lost), this could fall under the theft or comprehensive coverage section of your auto insurance. Reporting it early may speed up future claims and allow your provider to guide you on what’s covered, including lock replacement or rekeying expenses. Some policies even cover stolen personal items from inside the car, so it’s worth asking.
  • Rekey As Needed - If you're certain they were taken, rekey your locks or reset ignition access. Don’t wait as identity thieves often attempt house or vehicle entry within days.
  • Watch For Signs Of Follow-Up Theft Attempts - Be vigilant in the days that follow. If someone took your keys deliberately, they may be planning to return later to access your car or even your home. Check your garage entry points and any other areas that could be tied to the stolen keys. If a house key was also on the ring, consider changing your home locks as well.
Know Your Key Type
Understanding your key upfront can prevent future stress as it helps you know exactly who to call, what tools or technology might be needed in a lockout, and how complex (or costly) replacement could be. It also means you’re less likely to waste time with generic solutions that don’t fit your specific setup.
1. Traditional key:
a. What to Know: No chips, simplest form
b. Typical replacement cost: $10–$25
2. Transponder key:
a. What to Know: Embedded chip for ignition
b. Typical replacement cost: $50–$150
3. Remote fob:
a. What to Know: Locks/unlocks and starts remotely
b. Typical replacement cost: $200–$400+
4. Smart key (proximity):
a. What to Know: Unlocks automatically within range
b. Typical replacement cost: $300–$600+
Pro Tips to Avoid Losing Keys Again
Losing your keys once is frustrating, but losing them twice is a pattern. The good news is that it’s often preventable. While no one means to misplace their keys, a few intentional habits and tools can drastically lower the chances of it happening again:
  • Attach A Tracker - A small Tile or AirTag can help confirm location quickly.
  • Create Routines - Always hang keys on a hook or place them in a key bowl at home.
  • Duplicate Keys - Keep a spare in a safe place, such as your parent’s house, roommate’s drawer, or even a secure magnetic case under the car.
  • Plan - Have a locksmith program a spare fob even if you never need it
When to Replace Your Car Locks
Suppose your keys disappear under suspicious circumstances, such as being stolen along with your ID or lost near where your car is parked. In that case, it's smart to consider rekeying or replacing your locks to avoid security risks. This ensures that whoever might’ve found them can’t use them to access your vehicle. Rekeying changes the internal pins in your car’s locks, so old keys no longer work. This option is ideal if you’re on a budget. Complete lock replacement or electronic reprogramming is better if your vehicle uses a keyless system or if you're unsure how many copies of your key are out there.
Concerned about security or need immediate help? Explore roadside assistance plans that include lockout support and find a service that fits your needs.
